June Special: VIAIR 400H Hardmount Compressor Kit
Old Jun 2, 2012 | 01:33 PM
Air Werkz's Avatar
Former Vendor
Default June Special: VIAIR 400H Hardmount Compressor Kit
We have had great success with our monthly specials, and appreciate all the support and business. :thumb:
Continuing on with our specials, we will be offering the VIAIR 400H Compressor Kit with Hose for $215 with FREE shipping. This is a hard mounted unit, that can fill up to 35" tires, or even low pressure 37's up to 30-35 PSI.
This kit is really easy to install. Just find a spot to mount, wire directly to the battery and you are all set. It has a built-in on/off switch on the back, and comes with a braided coil hose with inline gauge.
400H Compressor Kit with Hose: $215
Free Shipping to Lower 48 States
Just use the coupon code "June" on our website to get the savings.
Included Parts:
- Installation instructions
- Mounting hardware (nuts, bolts, locking washers)
- Vibration isolators
- Remote mount air filter assembly
- Two replacement air filter elements
- Air line for remote mount air filter installation
- Stainless steel braided leader hose
- Check valve
- 1/4" quick connect stud
- 25 Ft. braided polyurethane coil hose with built-in 60 or 120 PSI gauge
- Intermittment deflation collar
- 3 pc. inflation tips kit
- Extra 1/4" NPT male quick connect stud
- Heavy duty storage bag for hose
Specifications:
12-Volt
Permanent Magnetic Motor
Duty Cycle: 33% @ 100 PSI
Max. Working Pressure: 150 PSI
Max. Amp Draw: 26 Amps
Max. CFM: 2.54
33" 15-30 PSI: 2:00 Minutes
35" 15-30 PSI: 2:20 Minutes
Old Jun 13, 2012 | 07:13 PM
Air Werkz's Avatar
Former Vendor
Just wanted to bring this up to the top for a simple solution to filling tires after the trail. Just mount, wire into the battery and your ready to fill tires!
Old Jun 13, 2012 | 07:29 PM
snopro269's Avatar
Thats 2 mins per tire?!? Yikes that's slow!! Sorry but I'm an impatient guy!!!
I last timed my power plant I thought it was about 4 mins plus change for all four 35's
Old Jun 13, 2012 | 07:44 PM
Air Werkz's Avatar
Former Vendor
Depends on what you compare it to. A large shop or home compressor, yeah maybe a little. Compared to a gas station compressor you put quarters in or other 12v compressors, no. I don't think 2 min. is all that long of a time to fill each tire, as you can do all four in 10 minutes. But, maybe I am patient and use it as time for a cold drink (no alcohol) before hitting the road.
I guess it is all relative though.
Old Jun 14, 2012 | 05:07 AM
damon.l's Avatar
two minutes per tire isnt that bad.
i think people just need to come to terms with the fact that these little compressors (all on board air compressors, not just the viair brand) are NOT the compressors they have in their shops/garage at home. you cant compare apples and oranges and expect the performance.
Old Jun 25, 2012 | 07:21 PM
Air Werkz's Avatar
Former Vendor
Last week to take advantage of this 400H hard mount kit with hose. Affordable solution if you just looking to fill up tires, with a very simple install.
Old Jul 2, 2012 | 08:58 AM
conifers4's Avatar
So upset with myself that I missed this deal! Two days late, the story of my life! Will stop whining now
Old Jul 2, 2012 | 09:13 AM
ZMagic97's Avatar
That's ok, I miss out too.
Old Jul 2, 2012 | 09:33 AM
Air Werkz's Avatar
Former Vendor
Don't worry guys. Give me a call and I will make sure to hook you up with a good price. In fact, we are having a 4th of July sale I will be posting soon that might save you a little more. Might be a good thing you missed out!
Old Jul 2, 2012 | 10:23 AM
ZMagic97's Avatar
Awesome, thanks for the heads up!
