Monster Valves & Deflators from PowerTank!
It will work, and it might be a little better because the holes are bigger on the Monster Valves. Balancing beads typically will almost always cause a leak issue. In my experience, balancing beads have always caused an issue with any type of air valve.
What are the chances of monster valves fitting on these rims?
It doesn't appear that there is enough lip to install and it would be tough to install where the valve stem is and then the inflator might not fit.
Any suggestions?
Any suggestions?
