New Currie JK Rock Jock Lift
#21
#22
#24
We are giving away the "Standard" entry level kit, CE-9807S.
http://www.currieenterprises.com/CES...9.aspx?id=3407
You can use either one if all you are concerned about is caster and pinion angle.
#25
I would have to say that is not the fault of Currie. You need to go to your dealer and have them remove the salescode from your TIPM. More than likely it will require them to get your vin and the salescode for the disco, login to dealerconnect, update the info with Chrysler, Chrysler will then send them a flash for your jeep. The dealer will then need to connect the starscan tool to yourjeep and flash the TIPM. That'll take care of it. The dealer you bought the jeep from usually does it for free. Others will charge anywhere from .2 hours to an hour to do it.
#26
2 door & 4 door springs??
Are there different spring rates for the 2 door and 4 door?????
If no would'nt the 2 door get more than 4" of lift ?
#27
Or is there anything else the full lift package that is not available seperately?
#28
