New - jk 2.5" coil spring suspension system by rock krawler available july 1st 2010!!
Shock Notes:
It is recommended that high quality shocks be used with all Rock Krawler Suspension Systems. The Rock Krawler RRD Racing Shocks are a great choice! Bilstein 5100’s are also a good choice.
Front Shock - 16" Collapsed to 27" Extended
Rear Shock - 16" Collapsed to 26" Extended
RRD Racing Shock Front Part Number RRD02054 ($134.99 Each) - Not Yet Available
RRD Racing Shock Rear Part Number RRD02055 ($134.99 Each) - Not Yet Available
Get a set of (4) RRD Racing Shocks for only $499!
Bilstein 5100 Recommended Part Numbers
Front - BE5-E1578-HO
Rear - BE5-E671-HO
Rear - BE5-E671-HO
with the overall height gain of the 2.5 mod kit, would an auto 2 door expect to have the same potential driveshaft rubbing/tearing issues that other coil lifts have with the stock shafts?
Yes, if you do not remove the OEM transmission cross member you stand the chance of cutting the boot on the front drive shaft. You need to account for the extra lift height and improved travel ranges. The best thing to do is remove the OEM tranny crossmember.
Rock Krawler
Rock Krawler
PM us with your email address and we will be glad to email you the instructions...
There are a few write ups in process regarding the new kits, but nothing is published just yet.
Rock Krawler
Rock Krawler
