New JK flip drag link for high-clearance knuckles for LH or RH drive!
Old 10-20-2016, 02:34 PM
Sponsoring Manufacturer
Rancho's Avatar
Cool New JK flip drag link for high-clearance knuckles for LH or RH drive!
We have just launched our flipped drag link for either a LH or RHD JK and is a perfect partner to our new high-clearance steering knuckles.
Limited Lifetime warranty!!!
Check with your favorite retailer on cost.
And our knuckles!!! It comes with the bump stop too!!!!!
Old 10-20-2016, 03:04 PM
Morghill's Avatar
This might be my next addition to the "Build"....
Old 10-21-2016, 05:16 AM
ShawnNoble's Avatar
Whats the MSRP and can you please give me a run down on the benfits of a flip drag link? Is it just for higher clearance or are there other benefits?
Old 10-21-2016, 06:50 AM
aldaman's Avatar
Nice
Question?
1) Is the drag link a direct bolt onto the HC knuckles? No drilling / tapering involved like some of the other kits.
2) Will it work on stock knuckles or is it just for the HC knuckles?
Thanks
Rancho's Avatar
I should be around $160 or so hopefully.
So using a flipped drag link with a high steer knuckle gets your steering up and out of the way. Another main benefit is at around 3" of lift you want to address the steering geometry and keep it all in line.
Other manufacturers will sell a whole drag link kit flip with a bracket, bolts etc. You will need to drill out the stock knuckle.
We sell a bracket so you can use the OE and our knuckle.
Old 10-21-2016, 07:04 AM
Rancho's Avatar
See below in bold ( I hope)
Originally Posted by aldaman
Nice
Question?
1) Is the drag link a direct bolt onto the HC knuckles Yes it will bolt right up? No drilling / tapering involved like some of the other kits.Correct on our knuckle, it tapered to accept this
2) Will it work on stock knuckles or is it just for the HC knuckles? It will not work on a stock knuckle with out drilling, at that point I would just get an EVO or Syngery (or the like) full kit.
Thanks
Old 10-21-2016, 08:12 AM
Rancho's Avatar
Quick video of the knuckles and the drag link.
http://youtu.be/e3w3_5p9YeY
Old 10-26-2016, 09:54 AM
Rancho's Avatar
Image of this drag link and our high-steer knuckles.
Quick Reply: New JK flip drag link for high-clearance knuckles for LH or RH drive!
