NEW PRODUCT: Rock Hard 4x4 C-Pillar Brace Kit for Jeep Wrangler JK4DR 07-Up [RH-1035]
Old Aug 25, 2016 | 02:57 PM
Rock Hard 4x4's Avatar
Former Vendor
Default NEW PRODUCT: Rock Hard 4x4 C-Pillar Brace Kit for Jeep Wrangler JK4DR 07-Up [RH-1035]
Learn more:
http://www.rockhard4x4.com/product_p/rh-1035.htm
Brace the vulnerable rear passenger and cargo area of your Jeep Wrangler JK Unlimited with our C-Pillar Brace Kit! ZERO welding required and minimal drilling. Our C-Pillar Brace Kit uses a 1/4" thick steel wheel well mounting plate, .120" wall, 1-3/4" OD tubing, and heavy duty hardware to securely install in your Jeep.
Installation Notes:
  • Removal of hardtop / soft-top NOT required.
  • Can be installed over or under carpet.
  • Can be installed over or under rear wheel well liner.
Instructions:
CLICK HERE TO DOWNLOAD
Old Aug 25, 2016 | 03:35 PM
RedSyndrome's Avatar
Nice, more protection is always better.
Old Aug 25, 2016 | 03:58 PM
Canvas's Avatar
Veteran: Navy
This is freaking awesome. Yet another safety feature from Rock Hard 4x4.
Old Aug 26, 2016 | 06:52 AM
Former Vendor
A few emails came in last night asking out how we mount the brace bar to the factory cage. We use our same proven patented collars we've used in our Ultimate Sport Cages for decades. 1 on each side, to make the secure connection. They are then hidden by the factory cage covers.
We threaded the cap this time instead of the collar to make install easier. This is why you do not have to remove your hardtop / soft-top to install. Now with the cap threaded, you can install from the bottom up, giving you much more wrench room.
Here's a quick pic showing the bolts being started in our JKU. You can see the collar in place. Minor padding trimming to fit the collar.
Old Aug 26, 2016 | 08:20 AM
wrangler311's Avatar
This is a great safety upgrade. Will you be offering a padding kit for this?
Old Aug 26, 2016 | 12:20 PM
Former Vendor
Yes. RH-1035-P. Just put on our site, no pics yet.
http://www.rockhard4x4.com/product_p/rh-1035-p.htm
Old Aug 26, 2016 | 01:28 PM
Awesome! I will definitely be placing an order.
Old Aug 26, 2016 | 04:47 PM
pxb006's Avatar
Will this work with the Trek Top? Looks like where it mounts may interfere with bracket where spring attaches.
Old Aug 26, 2016 | 05:09 PM
Former Vendor
Post a photo of where you think the interference will be.
Old Aug 26, 2016 | 05:10 PM
RenegadeUL13's Avatar
Originally Posted by Rock Hard 4x4
Learn more: http://www.rockhard4x4.com/product_p/rh-1035.htm Brace the vulnerable rear passenger and cargo area of your Jeep Wrangler JK Unlimited with our C-Pillar Brace Kit! ZERO welding required and minimal drilling. Our C-Pillar Brace Kit uses a 1/4" thick steel wheel well mounting plate, .120" wall, 1-3/4" OD tubing, and heavy duty hardware to securely install in your Jeep. Installation Notes:[*]Removal of hardtop / soft-top NOT required.[*]Can be installed over or under carpet.[*]Can be installed over or under rear wheel well liner. Instructions: CLICK HERE TO DOWNLOAD
what makes it vulnerable? Is their evidence to suggest the roll bar is not sufficient? If so, id like to see it.
