NEW!! TeraFlex JK Leveling Kit!! $129.99
[QUOTE=Littlejon;1050228]The reason for the spacer is because in the rear the sway bar end links they send can rub the wheel and tire under extreme articulation. You could get the Currie end links, and this would fix the issue, or you could run spacers. This is the same issue that was on the budget boosts. I couldn't find a picture with the wheel installed, but here you can see how close it is to the brake caliper.
They only send front swaybar links, you continue to use stock on the rear because you're only installing 1" spring spacer in the rear.
Is there a 1.5" rear spacers available? If so, is it possible to switch 1" for 1.5" spacers. I wanna level the Jeep a bit but not that level. I sometimes carry heavy stuff in the back and I still have stock front bumper....
Thank you!
Thank you!
so with this kit do you not need anything else? doesnt mess with the steering or the esp or the brakes or anything? was trying to avoid a lift but going with 295/70/17 tires with xhd stinger bumper and winch figure i need at lease a front 1inch spacer, thought this would be even better. anythoughts?
If you have the factory sway bar disconnects and factory shocks, will this be ok by itself? Or do I need new shocks?
Also, will 34s rub with the disconnects up front?
Additional what if question...If you have bumpers and a front winch, will 34s still fit?
i bought this kit and installed it this past week, i'm very happy with it. I like how it rides now, stock ride was a little soft for me. Easy install, i did it in 2hrs but i'm an aircraft mechanic/electrican so i can normally do some jobs a little fast than most. heres a pic of it finished
I got a question about this product. I currently have the 2.5 TF coil lift with shocks and I need a little more lift with my 35's. Is this something that would work for me to add on to the lift I currently have? Would I need a front sway bar link or keep the one I have on currently?
I have the 2" FT Budget Spacer lift with Rubicon shocks with Teraflex shock extensions and extended Teraflex sway bar disconnects. Can I add these spacers to my FT or can I add them to the Teraflex 2 1/2" Coil lift that is next on my list?
