Orw now has rotopax in stock
Sponsoring Vendor
ORW Representative
ORW Representative
ORW NOW HAS ROTOPAX IN STOCK
RETURN TO THE DESERT SALE !
The 2011/2012 Desert Season has started, and the one thing that is always in the back of our mind while on the trail, sand, or rocks,
It doesn’t matter if you are in a Buggy, Truck, Bike, or Jeep, you are having too much fun to remember if you started out with a full tank, or just what you had in the tank from the last run.
To better manage you vehicle's fuel consumption, and insure that you have a sufficient supply on the trail or back at camp is “RotopaX” modular system to contain all of your liquid needs on and off road. RotopaX is an exclusive, modular system that allows you to customize 2-3 Gallon packs according to your varying needs. It takes only seconds to switch between:
Gasoline
Water
Diesel
Kerosene
2-Cycle
Emergency Packs
First Aid Packs
Utility Packs
RotopaX ARE THE ONLY EPA AND CARB COMPLIANT FUEL CONTAINERS AVAILABE FOR SALE IN THE UNITED STATES!
RotopaX utilize widely-available mounting brackets which make mounting and storing your RotopaX even easier. And remember that our packs can be used separately as well.
As your requirements change from day-to-day, RotopaX is the only system that gives you the freedom to mix and match your packs at will. If you need a different pack in the future, you can easily merge it into your existing RotopaX system. Now that’s innovation!
ORW is offering this new product to our Forum Customers for a limited time for:
ROTRX-2G/2GALLON GAS CAN $57.00
ROTRX-3G/3 GALLON GAS CAN $75.00
ROTRX-2W/2 GALLON WATER $37.99
ROTRX-DLX-PM/ROTOPAC LOCK $28.99
ROTRX-LOX-PM/ROTOPAC KEY LOCK $38.99
For more information or to place your order, please PM, E-mail, or Call.
“Do I Have Enough Fuel?”
Gasoline
Water
Diesel
Kerosene
2-Cycle
Emergency Packs
First Aid Packs
Utility Packs
Great!!!!!!! just what I need.... another sale on something on my wish list......this addiction is getting out of hand!!!
I sooo want 2 of those but need to fix this steering issue I have first...any idea on how long this sale will be going on...hopefully till after the first of the year!!!!
