Poison Spyder JK RockBrawler Front Bumper
Old Sep 27, 2012 | 10:04 AM
DTS's Avatar
DTS
Former Member
Default Poison Spyder JK RockBrawler Front Bumper
Most of you are familiar with our famous Brawler Lite front bumper for the JK. Have you ever wondered why we call it the Brawler LITE? Its because its a lighter, simpler version of our original RockBrawler bumper for the JK. The original JK RockBrawler Front Bumper is still available, for those who want a heavy duty, full featured but high clearance rock crawling bumper with integrated lower skid, stinger bar, fairlead mount plate, and more. Read on for more details on the original JK RockBrawler Front Bumper!
Poison Spyder Customs RockBrawler™ is the bumper of choice for the wheeler who wants pure hardcore function coupled with a brawny attitude. The RockBrawler™ is fabricated from 3/16" high pressure steel plate, CNC laser cut and brake-formed for a precise fit. The Stinger is made of 1.75" X .120 wall DOM tubing, and extends inside the bumper shell to the inner braces for added strength.
The two D-ring shackle mounts are CNC-machined from 1" plate steel to provide brute strength for the most demanding recovery operations. Speaking of recovery, the integrated winch mount accepts most major manufacturer's winches up to 15,000 lbs. capacity, including the innovative Warn PowerPlant with integrated air compressor. The winch fairlead plate is flawlessly integrated into the bumper design, and doubles as gusseting for the Stinger, complete with Poison Spyder's signature oval lightning holes. Recessed light mounts are provided for retention of the factory fog lamps or aftermarket off-road lamps of your choice, and protect each one in a deep well of cold hard steel.
Another characteristic of the RockBrawler™ is its amazing tire clearance. The bumper has faceted ends that angle inward, giving your Jeep the ultimate in clearance for large tires, even under maximized suspension movement, and during full turn scenarios. The angled sillouhette of the bumper ends allow for this tire clearance while still protecting the lower corner of the Jeep's grille. The RockBrawler™'s removable lower cover has an integrated skid plate for protecting the front sway bar disconnect mechanism. Jeep JK models that are not equipped with the factory sway bar disconnect can still utilize this lower skid as added protection for the front end components. The fasteners for this cover/skid, as well as all external fasteners provided with the RockBrawler, are stainless steel flat-head cap screws for a flush surface and protection from the rocks.
Click HERE to go to the original JK RockBrawler Front Bumper on our website!
Old Sep 27, 2012 | 10:27 AM
TURTLECON's Avatar
Does this require cutting of the frame like your BFH or is it 100% bolt on?
Old Sep 27, 2012 | 10:41 AM
DTS's Avatar
DTS
Former Member
It is 100% bolt-on. However, on some later model JK's it may require some minor trimming of the ends of the crash bar.
