question for Tera Flex...
The rear track bracket I have is not matching up. The bolt holes in the bracket and the frame are off center by at least 1/4 of an inch. The sholders on the bracket will not allow me to push the bracket farther into the frame for bolt hole alignment. Thank you...Wesley
![Don't Know](https://www.jk-forum.com/forums/images/smilies/z0tdntknw.gif)
Sponsoring Manufacturer
The rear track bracket I have is not matching up. The bolt holes in the bracket and the frame are off center by at least 1/4 of an inch. The sholders on the bracket will not allow me to push the bracket farther into the frame for bolt hole alignment. Thank you...Wesley ![Don't Know](https://www.jk-forum.com/forums/images/smilies/z0tdntknw.gif)
