Rough Country 3 1/4" Progressive Spring lift kit
Old Jul 15, 2009 | 02:05 PM
rcjeep's Avatar
Sponsoring Manufacturer
Default Rough Country 3 1/4" Progressive Spring lift kit
If you are looking for a great riding kit that clears up to a 35" tire and won't break the bank... this is it. This new kit includes: (4) progressive rate springs, (4) performance 2.2 shocks, (4) 3/4" poly spacers, (2) extended sway bar links, (1) rear track-bar bracket, brakeline relocation brackets and hardware. Priced @ $379.95
http://www.roughcountry.com/jeep_jk_3.html
Optional: Sway Bar Discos for $59
Old Jul 16, 2009 | 10:00 AM
hohokom's Avatar
I wish I had waited now for another month, and I would have purchased this kit instead of the 2.5 one I did. Is there anything I can put on this kit to get a little more heigth, as it seems to have settled since I put it on.
Old Jul 16, 2009 | 12:23 PM
yellowjeeper85's Avatar
you could just add a set of 3/4 inch poly spacers.... it appears as thought these are the springs from the 2.5" kit... at the 3/4" poly spacers and you're at 3 1/4"
Old Jul 16, 2009 | 02:15 PM
rcjeep's Avatar
Originally Posted by planman
Is the reason there are no brakeline relocation brackets because these are the shorter shocks from the 2.5" lift, or are these the shocks from the 4" lift?
Are the swaybar links the same as the 4" kit?
Do you have a timeline on if or when you will offer adjustable lower front control arms, adjustable rear upper control arms, and an adjustable front trackbar for this kit?
Thanks.
Sorry, I left out the brakeline relocation brackets. They have been added.
Yes same swaybar links as the 4" kit
Yes, Adj arms are in the works and are being tested, but I don't have a timeline on the release yet. Same goes for the Adj. Trackbar.
Old Jul 17, 2009 | 07:02 AM
rcjeep's Avatar
Thanks.
So, the shocks are from the 4" lift or 2.5" lift?
The kit includes the same shocks as the 2.5" kit.
