Rusty's Off-Road "weekly" specials
Old Jul 1, 2013 | 11:37 AM
  #41
RustysTech's Avatar
Sponsoring Manufacturer
Rusty's Off-Road
Our latest deals are up!
Here is the link for all of them:
Rusty's Sales & Clearance
Some highlights!
Our new HD diff covers!! Available in 30,35,44,60 (this is the 30)
Normally $99.00 now $85.00!
Constructed of 1/4" laser-cut steel that is then CNC formed for a precision fit, these covers can handle anything you throw at them! Once formed, they are set up in a jig and robotically welded to ensure a leak-free seal that will last for the life of the differential and beyond. The cover features a ring that will prevent the fill plug from damage. The HD construction even helps reinforce the differential housing and prevents the casting from deflection under extreme loads. This is the best USA-made differential cover that money can buy! We could call them bulletproof, and they are, but other have already made those claims with cheap imported covers. Needless to say, this is the last differential cover you'll ever buy for your rig.
KEY FEATURES:
CNC formed for precision fit
Simple bolt-on installation with all hardware provided
Made in the USA
Our new JK front and rear bumper package!
$699.00 for a front AND Rear bumper!
Rusty's Bumpers - JK Trail Package - SALE!
Rusty's Front Trail bumper is also packed with features you'd expect from much more expensive bumpers! Our JK bumper comes standard with two solid D-ring attachment points. You can also add the optional pre-runner bar, which adds protection for the winch and a pair of light tabs as well as an aggressive look. The light tabs were built to accommodate two small spot or driving lights, or a single Rigid LED light bar! It all adds up to one solid bumper that includes everything a serious off-roader needs along with the good looks to match!
Rusty's Trail Rear Bumper is constructed of 3/16" thick steel that has been laser-cut and CNC-formed for an exact fit. Our computer-aided design emphasizes strength while eliminating unnecessary weight. This bumper will also work with the factory rear receiver hitch. The ends of the bumper are tapered for improved clearance on the trail and to maximize departure angles, and comes standard with two solid D-ring attachment points. Just like the front, this is one solid rear bumper that won't let you down in the rough!
Please note the bumpers come standard in a Semi-Gloss Black Wrinkle powdercoated finish. Also note that the front pre-runner hoop shown in the pictures is an optional upgrade.
FRONT
REAR
Old Jul 7, 2013 | 07:08 PM
  #42
ucfjeep's Avatar
Do you all have anymore photos of the rear bumper. I have searched around and can't find any. I would like to get a new rear bumper but have yet to find one I like.
Old Jul 7, 2013 | 07:34 PM
  #43
nickell586's Avatar
That rear bumper is sick! I've been thinking about building one because I can't find one I like.... I'm liking this one
Sent from my Nexus 7 using Tapatalk 2
Old Jul 10, 2013 | 11:51 AM
  #44
RustysTech's Avatar
Rusty's Off-Road
Working on more pictures for you guys!
Thanks !
Old Jul 18, 2013 | 11:35 AM
  #45
RustysTech's Avatar
Rusty's Off-Road
This weeks specials are up!!!
Our MasterCraft Safety Nomad seats and harness deal.
$500! This is a SCREAMING deal!
Don't miss out on this incredible deal! For a limited time, you can buy this special bundle that includes a pair (2) of Mastercraft Nomad seats AND a pair (2) of 5-point safety harnesses! Buy everything you need for your two-seater and save HUGE!
About Nomad Seats:
The new Mastercraft Nomad Seat is a lower-priced alternative to the conventional Mastercraft seats we sell. It features much of the same quality and comfort features you would expect from Mastercraft, but in a lower cost alternative.
After years of development, the MasterCraft Safety Nomad Seat has arrived! The Nomad is a fixed back, import seat based on the legendary Rubicon suspension seat design. Not just another Import seat with the Mastercraft name slapped on it, the Nomad is a true suspension seat that was designed from the ground up and is built to Mastercraft specifications. Nomad seats feature the same tubular steel frame and open mesh liner construction as the legendary Rubicon seats and even share the same mounting configuration, so they will fit anywhere the Rubicon seats do, and use the same mounting kits and brackets for those vehicles that require them. Upholstered with FMVSS rated fabrics means these seats are colorfast to the same standards as the OE manufacturers.
Available in black only.
About Mastercraft Non-Racing Restraints:
All 3in. driver restraints are SFI-16-1 approved. Our hardware is manufactured from sheet alloy steel or drop forged alloy steel, with military spec webbing. Most sanctioning bodies require all belts/systems be re-webbed or replaced two years after the date stamped on the SFI tag. This is done for your safety. Available webbing colors include: Red, Blue & Black.
Most commonly used for racing applications 5-way latch & link belts
Seat Belt: 3in. wide x 50in. long, pull down adjustment w/ Velcro latch guard cover
Harness: 3in. wide individual, pull down adjustment
Anti-Sub: 2in. wide
Shown with optional Sternum Protector
Restraints can not be returned.
Rustys 5.75" Long Arm system 2 or 4 door.
$2100 normally $2350!
Rusty's new JK long travel kit is the result of many hours of computer-aided design, prototyping in the shop, and extensive testing on teh street and on the trail. We use our proven radius arm system in the front as well as the rear, something we had previously used only on local custom vehicles. Unlike many other JK long-arm systems, Rusty's JK system can be installed in just about any garage, but note that it does require welding.
We spent many hours developing our new long travel mounting brackets using our keyed and tabbed bracket technology. In simple terms, the .25" thick brackets are laser cut and CNC formed. Once formed on the press brake, the keyed and tabbed technology bracket simply snap together like a puzzle. This means precision fit and exact placement of all the individual components that make up the mounting brackets without the use of a jig.
The massive Rusty's control arms are constructed of 2" DOM tubing and use our Forged Flex Joints. These joints are adjustable to dial in castor and pinion angles, and can be serviced as well as rebuilt. Both the lower arm and the upper links are adjustable.
Due to the factory-style driveshafts that use Rezeppa-syle non-serviceable U-joints, we strongly recommend doing a driveshaft conversion for both front and rear driveshafts.
Key Features:
• Great ride and handling
• All control arms are adjustable
• Fits 4 door JKs
• Latest design in fabrication
• Massive 2 inch DOM tubing
• Serviceable flex joints
Kit Includes:
• Front 5.75" Coil Springs
• Rear 5.75" Coil Springs
• Adjustable Front Track Bar
• Adjustable Rear Track Bar
• Front and Rear Shock Absorbers (Upgrades Available)
• Adjustable Radius-Style Arms Front and Rear
• Front and Rear Control Arm Frame Hangers
• Drop Pitman Arm
• Extended Sway Bar Links
• Extended Front and Rear Brake Lines
• JKS Quick-Disconnects
Front and rear JK bumpers
$699!! for both! Wow!
For a limited time, buy Rusty's front and rear Trail bumpers as a package and SAVE!
All of Rusty's bumpers are proudly Made In the USA! There's none of that flimsy imported stuff here; Rusty's bumpers have been Trail Tested Tough for over 30 years.
Rusty's Trail Front Bumper for the JK combines the protection you need for serious trail work with a look that's right at home when cruising your local hangout. The Trail bumper is constructed of 3/16" thick steel that has been laser-cut and CNC-formed for an exact fit. Our computer-aided design emphasizes strength while eliminating unnecessary weight. The ends of the bumper are tapered for improved clearance on the trail and to maximize approach angles, while a durable black wrinkle coat finish keeps the bumper looking good for years to come and matches the look of the fender flares. The bumper is also pre-drilled to accept most winches, so there's no need for an extra winch plate. This is one solid front bumper that won't let you down in the rough!
Note: Will not accommodate a Zeon Series WARN Winch.
Old Aug 7, 2013 | 08:45 AM
  #46
RustysTech's Avatar
Rusty's Off-Road
Our latest deals are up!!!
Two MasterCraft seats and restraints!
$500
About Nomad Seats:
Anti-Sub: 2in. wide
JK Bumper Package
$699
KEY FEATURES:
• Front AND rear bumper package
• Made in the USA quality
• Integrated winch mount in front bumper
• Constructed of 3/16" thick steel
• Sturdy D-ring recovery points included
• Optional front prerunner bar adds winch protection and two light tabs
• Rear bumper works with the factory receiver hitch
• Durable black powder coated finish
• Multiple options available to meet many different needs
Rusty EVAP Skid
$95
If you own a 2007-2011 Jeep Wrangler JK, it’s not a question of if, but when, the evaporative canister will get damaged or entirely ripped off on the trail. For some reason the factory mounted the canister in an extremely vulnerable spot on the undercarriage near the middle of the vehicle. There are some relocation kits on the market that move the low-hanging canister to a safer location, but this can cause check engine lights and also may not be legal in some states. Fortunately, Rusty’s Off-Road Products has an affordable solution that keeps the canister protected without altering the factory emissions system.
The emissions control system on the Jeep JK is extremely sensitive and will cause the check engine light to illuminate when it thinks there’s even the tiniest of problems. The evaporative canister (sometimes called the charcoal canister) is a critical part of the emissions system, yet Jeep engineers mounted it in a location where it is virtually guaranteed to get snagged by rocks and other obstacles on the trail. Damage to the canister can cost hundreds of dollars to fix, not to mention causing a lot of aggravation.
Rusty’s Evaporative Canister Skid Plate provides effective and affordable protection without the need to alter any of the factory emissions system. Constructed of 1/4” thick steel, the skid plate provides 100% coverage of the canister and keeps it safe from harm. Best of all, the skid plate utilizes factory mounting holes, so installation is a simple, no-drill operation! A durable black powdercoated finish ensures that the skid plate will keep looking good for years to come.
KEY FEATURES:
• Protects the Evaporative Canister from trail damage
• Leaves the canister in the factory location to prevent Check Engine lights
• Constructed of 1/4" thick steel
• Durable powder coated finish
• Easy bolt-on installation
Front
Rear
Old Aug 13, 2013 | 12:58 PM
  #47
RustysTech's Avatar
Rusty's Off-Road
Default JK Advanced 3.25" system on sale!!!!
All specials here!
This comes around a few times a year, so take advantage of this great opportunity!
$1,320.00
For a limited time only, save $130 on this kit! Normally $1450!
Rusty's JK Advanced Kit is our highly successful 3.25" JK basic kit with all the bells and whistles! Designed using 3-D computer modeling and subjected to severe testing in the field, this kit offers factory ride and handling with the off-road performance you desire. This kit easily clears 35 inch tall tires and is completely bolt-on, making it ideal for shadetree mechanics.
The Rusty's JK Advanced Kit comes with a complete set of replacement front and rear coil springs that are designed to maintain the excellent ride you're accustomed to while delivering substantially better off-road performance. The axles are properly centered under the frame with our front and rear adjustable track bars. Unlike many other systems, we avoid using wimpy brackets that break or over-stress the factory brackets on the axles due to additional leverage. The front axle is held in place by Rusty's front control arm system for proper camber and wheelbase adjustments, while adjustable lower arms are included for the rear to dial-in driveline angles. Rusty's standard (non-Rubicon) kits even include JKS sway bar quick-disconnects for additional off-road performance! Extended-length stainless steel brake lines are also included that provide the length necessary to accommodate the additional flex and suspension travel that this kit provides. Rusty's Hydro shocks round out this complete and very capable package.
Rusty's Coils - JK 5.75" Rear or Front
Regular Price: $140.00
Sale Price: $120.00
Old Aug 20, 2013 | 10:27 AM
  #48
RustysTech's Avatar
Rusty's Off-Road
Cool
Specials for the week of August 17, 2013
See all specials here!
MasterCraft Seats!
$500 for two seats and harness!
AIRAID MXP Cold Air Intake - JK Wrangler ('12-'13) - Oiled Filter
310-132
Regular Price: $329.90
Sale Price: $299.00
The best way to bolt on more horsepower and torque while improving air flow to a gas engine is with an AIRAID® Intake System. All AIRAID® Intake Systems are computer designed, dyno tested and tuned to extract maximum performance for each application.
Improving airflow to the engine is just one part of what AIRAID® Intake Systems are designed to accomplish. It is a scientific fact that cold air is denser than hot air, so therefore cold air packs more oxygen molecules into an engine. More oxygen means more complete combustion, and more combustion equals more power. AIRAID® Intake Systems replace your vehicle’s restrictive factory air box with a computer-designed Cold Air Dam (CAD), which separates the AIRAID® premium filter from hot engine compartment air while supplying the filter with plenty of cool outside air. This cool, dense air charge is the key to getting more power from your engine. Most AIRAID® Intake Systems are smog-legal and utilize factory mounting points for ease of installation. Last but certainly not least, all AIRAID® products are constructed using the finest materials available today and backed by an exclusive Lifetime “No-Hassle” Warranty.
FEATURES:
• AIRAID MXP Series Cold Air Dam Intake System
• SynthaFlow oiled filter
• Includes Intake Tube
• Easy To Install w/Basic Hand Tools
$699.00 Front and Rear bumper!!!
KEY FEATURES:
Front
Rear
And our new key chain holders!!
XJ
CJ
JK
Old Aug 28, 2013 | 08:59 AM
  #49
RustysTech's Avatar
Rusty's Off-Road
Default Bolt On Long Travel Arms and system for your JK and more specials!
Rusty's JK Wrangler Bolt-On Long Travel Upgrade
$1,490.00
So you already have a suspension kit and now you want a long arm kit? This is your kit! This is the same long travel arms and bolt-on brackets offered in our JK Bolt-On Long Travel Kit.
Rusty's JK long travel kit is the result of many hours of computer-aided design, prototyping in the shop, and extensive testing on the street and on the trail. We use our proven radius arm system in the front as well as the rear, something we had previously used only on local custom vehicles. Unlike many other JK long-arm systems, Rusty's JK system can be installed in just about any garage, but note that it does require welding.
Key Features:
• 100% Bolt-On Installation; no welding required
• Fits 2 door and 4 Door JKs
Rusty's JK Wrangler 5.75" Bolt-On Long Travel Kit
$2,099.00
Fits 2007-Current 2-Door and 4-Door JK Wranglers.
Rusty's newest version of our popular JK long travel kit is a bolt-on system. It uses many of the same components as our popular weld-on system but offers an easier installation for those that don't have the necessary welding skills and equipment. It's just as strong as our weld-on kit, and just like the rest of our products, it's trail-tested tough!
Rusty's JK Long Travel kit is the result of many hours of computer-aided design, prototyping in the shop, and extensive testing on the street and on the trail. We use our proven radius arm system in the front as well as the rear, something we had previously used only on local custom vehicles. Unlike many other JK long-arm systems, Rusty's JK system can be installed in just about any garage.
We spent many hours developing our bolt-on long travel mounting brackets using our keyed and tabbed bracket technology. In simple terms, the .25" thick brackets are laser cut and CNC formed. Once formed on the press brake, the keyed and tabbed technology brackets simply snap together like a puzzle. This means precision fit and exact placement of all the individual components that make up the mounting brackets without the use of a jig. Like the name implies, these brackets bolt into place using the supplied hardware; no welding is required.
The massive Rusty's control arms are constructed of 2" DOM tubing and use our Forged Flex Joints. These joints are adjustable to dial in caster and pinion angles, and can be serviced as well as rebuilt. Both the lower arm and the upper links are adjustable.
Please note that 2012-2013 JKs will require new exhaust crossover pipe for front driveshaft clearance. We offer a pre-bent crossover pipe separately: RS720003
Key Features:
• 100% bolt-on suspension kit
• Adds 5.75" of lift
• Fits 2 and 4 door JKs
Kit Includes:
• Dropped Pitman Arm
• Bolt-On Front Crossmember and Braces
• Bolt-On Rear Control Arm Frame Hangers
• Adjustable Rear Sway Bar Links
All the other specials!
Click the link to see them all!
Old Oct 14, 2013 | 11:34 AM
  #50
RustysTech's Avatar
Rusty's Off-Road
Smile
It's been a while!
A lot going on though. We are making a lot of new products for the JK, you can see them on our Facebook page!!!
https://www.facebook.com/RustysOffRoad
Here are our latest deals:
Some highlights:
2 bumpers for...
$699.00
And don't forget our garage sale at our shop!!!
