Rusty's Off-Road "weekly" specials
Old Jan 27, 2014 | 09:11 AM
  #61
RustysTech's Avatar
Sponsoring Manufacturer
Rusty's Off-Road
Default Weekly specials January 27, 2014
Originally Posted by Jungle_JK
Wish I had known about these bumps before pulling the trigger on a smittybilt XRC front. Will definitely be getting that rear in the next few days.
Very cool and thanks!!!
The latest deals are up!!!
Rusty's Sales & Clearance
We still have the bumper deal for the JK up still.
$699 for front and rear bumpers!!!
Rusty's Bumpers - JK Trail Package - SALE!
FRONT
REAR
EVAP Skid
$109
Rusty's JK Wrangler Evaporator Skid Plate
Old Mar 10, 2014 | 08:16 AM
  #62
RustysTech's Avatar
Rusty's Off-Road
Cool Specials for March 10, 2014
A TON of JK deals this week, check them out!
Give us a call today!
ARB JK Snorkels
Regular Price: $516.00
Sale Price: $445.00
ARB JK Snorkels
Anyone who has spent time in off road environments almost certainly would have experienced one of these situations, although a solution to the problem is rarely considered until costly engine damage has already occurred.
A Safari snorkel system relocates your engine's air intake point from the relatively low and vulnerable position under the hood to a much higher and safer location where a constant source of cool, clean, dry air is available.
Manufactured from premium quality polyethylene, Safari snorkels are incredibly resilient and UV stable. Install one before your next trip and breathe easier knowing that your engine is protected by a Safari snorkel.
$699.00
A front and rear bumper for $699!!!
All of Rusty's bumpers are proudly Made In the USA! There's none of that flimsy imported stuff here; Rusty's bumpers have been Trail Tested Tough for over 30 years.
Rusty's Trail Front Bumper for the JK combines the protection you need for serious trail work with a look that's right at home when cruising your local hangout. The Trail bumper is constructed of 3/16" thick steel that has been laser-cut and CNC-formed for an exact fit. Our computer-aided design emphasizes strength while eliminating unnecessary weight. The ends of the bumper are tapered for improved clearance on the trail and to maximize approach angles, while a durable black wrinkle coat finish keeps the bumper looking good for years to come and matches the look of the fender flares. The bumper is also pre-drilled to accept most winches, so there's no need for an extra winch plate. This is one solid front bumper that won't let you down in the rough!
Note: Will not accommodate a Zeon Series WARN Winch.
Rusty's Front Trail bumper is also packed with features you'd expect from much more expensive bumpers! Our JK bumper comes standard with two solid D-ring attachment points. You can also add the optional pre-runner bar, which adds protection for the winch and a pair of light tabs as well as an aggressive look. The light tabs were built to accommodate two small spot or driving lights, or a single Rigid LED light bar! It all adds up to one solid bumper that includes everything a serious off-roader needs along with the good looks to match!
Rusty's Trail Rear Bumper is constructed of 3/16" thick steel that has been laser-cut and CNC-formed for an exact fit. Our computer-aided design emphasizes strength while eliminating unnecessary weight. This bumper will also work with the factory rear receiver hitch. The ends of the bumper are tapered for improved clearance on the trail and to maximize departure angles, and comes standard with two solid D-ring attachment points. Just like the front, this is one solid rear bumper that won't let you down in the rough!
Please note the bumpers come standard in a Semi-Gloss Black Wrinkle powdercoated finish. Also note that the front pre-runner hoop shown in the pictures is an optional upgrade.
2 JK systems!!!
Rusty's JK Wrangler 5.75" Bolt-On Long Travel Kit - SALE!
Fits 2007-Current 2-Door and 4-Door JK Wranglers.
Rusty's newest version of our popular JK long travel kit is a bolt-on system. It uses many of the same components as our popular weld-on system but offers an easier installation for those that don't have the necessary welding skills and equipment. It's just as strong as our weld-on kit, and just like the rest of our products, it's trail-tested tough!
Rusty's JK Long Travel kit is the result of many hours of computer-aided design, prototyping in the shop, and extensive testing on the street and on the trail. We use our proven radius arm system in the front as well as the rear, something we had previously used only on local custom vehicles. Unlike many other JK long-arm systems, Rusty's JK system can be installed in just about any garage.
We spent many hours developing our bolt-on long travel mounting brackets using our keyed and tabbed bracket technology. In simple terms, the .25" thick brackets are laser cut and CNC formed. Once formed on the press brake, the keyed and tabbed technology brackets simply snap together like a puzzle. This means precision fit and exact placement of all the individual components that make up the mounting brackets without the use of a jig. Like the name implies, these brackets bolt into place using the supplied hardware; no welding is required.
The massive Rusty's control arms are constructed of 2" DOM tubing and use our Forged Flex Joints. These joints are adjustable to dial in caster and pinion angles, and can be serviced as well as rebuilt. Both the lower arm and the upper links are adjustable.
Due to the factory-style driveshafts that use Rezeppa-syle non-serviceable U-joints, we strongly recommend doing a driveshaft conversion for both front and rear driveshafts.
Please note that 2012-2013 JKs will require new exhaust crossover pipe for front driveshaft clearance. We offer a pre-bent crossover pipe separately:
Rusty's JK Wrangler 2" Basic Kit - SALE!
$320.00
Rusty's 2 inch suspension kit is economically priced, yet Rusty's used 3-D computer modeling to design the whole system. It provides clearance for 33 inch tires and more articulation, yet maintains the factory's excellent ride quality. The Rusty's kit comes with a complete set of replacement front and rear coil springs as well as a set of Rusty's Hydro shocks. The front coil springs have a 150-pound rate and the rear coils have a 170-pound rate for optimum ride quality.
Old Mar 24, 2014 | 09:08 AM
  #63
RustysTech's Avatar
Rusty's Off-Road
Latest deals are up!
JK ARB Snorkles
ARB JK Snorkels
ARB JK Snorkels
Sale Price: $445.00
KEY FEATURES:
UV stable crosslinked polyethylene body for the ultimate in strength
High flow air ducting & body ensures air supply in excess of engine requirements
Each component is designed for maximum dust & water sealing
Stainless steel & plated hardware for corrosion resistance
Fully compatible with optional 7" or 10" precleaners ~ some models
Unique evacuation system effectively disperses rain and unwanted moisture
Completely Australian designed & manufactured
FRONT AND REAR BUMPERS!
$699.00
Old Apr 4, 2014 | 08:50 AM
  #64
geerhed's Avatar
Any idea when y'all might put the 2" Basic JK lift back on sale? I'm wanting to get that very soon. Thanks!
