Slickrock Gear JK forum Special Offer *** 10% off JK Pockets ***
Former Vendor
Everyone who owns a JK either doesn't use their door nets, or eventually suffers from the unsightly Saggy Sack!!
Slickrock Gear's JK Pockets are the first "real" door pockets for the 2011-2018 Jeep Wrangler JK!
Like many JK owners, we found the factory door netting to not be very useful, and even worse if anything with any weight is put into the netting it stretches out. Depending on where you live, the age of your JK, and how often you run with the top off you also find that the netting starts to deteriorate and fall apart. Many owners just end up not using the door nets at all, and some resort to just cutting it out because it ends up looking terrible.
Features
JK Pockets are available in solid black with a texture very close to OEM, black carbon fiber, and 11 other colors if you want to make your interior pop.
JK Forum Members save 10% for our introductory special thru 4/12/2019 using the code "jkforumintro" on our shopping cart page.
For more information and a photo gallery visit https://www.slickrockgear.com/about-jk-pockets/
Order full sets or whichever pieces you like at https://www.slickrockgear.com/jk-pockets/
Features
- Made from aircraft-grade, fire retardant plastic
- Excellent impact strength, abrasion resistance, rigidity, and chemical resistance
- Easy to install - takes an average of 5 minutes per piece
- Pressure fit - no rattles and requires no tape
- Optimized depth - no interference with other factory features and unobtrusive to the occupants
- Stepped feature across the top edge for increased rigidity
