Superior Evolution series axles
Wanted to know if it is common for the axle seals to start leaking due to the evolution shafts being slightly narrower? whats the best solution to fix this? or is changing out the seals the only alternitive. also, would using a set of tube seals help in this situation? thanks
FWIW - I was under two different JK's (besides mine) this weekend comparing different suspension systems. All 3 (mine included) had stock shafts and all three had leaking axle seals on the passenger side front. 2 were Rubis and 1 was a X.
Man that drove me crazy until I fixed it. Here's how if you're wondering:
https://www.jk-forum.com/forums/show...ght=axle+shaft
I have the new seal for the Superior shaft and one of these days I'll get back under and do it again.
