This is for Teraflex
I am fairly new to the forum and have been doing alot of research on mods before i even purchase my jeep. It seems that anyone that has gone with your lifts has no major complaints. So at this point your my choice. my question is, will a 2 door X with your 2.5 BB sit the same height as a rubicon with the same lift? I have asked others and have gotten mixed responses. Also, what is the tallest lift I can put on a two door without having to change out driveshafts? Currently I am torn on weather I should get an X with lockers or just bite the bullet and get a rubicon. I like the fact that the rubicon sits higher off the lot and has 4.10s. i plan on getting 34 or 35's and using factory wheels with spacers. i want a kit that is complete. I dont want to buy a kit and have to buy seperate parts to fix any problems that come into play with 2 door JK's. What kit would you recommend?
Thanks for your inquiry and protecting this country!
I would like to get rid of the rake yes. Also how much does the 4 coil 2.5 lift cost roughly? Would there be any other purchases that would need to be made like pitman arm or any relocaton brackets? Or am I being paranoid?
$599.99 at Northridge with free shipping. Can't beat it. Or check the Teraflex website and order direct. As far as accessories go, a steering stabilizer is a must for bigger tires, and although not direly needed, you will probably want a frt adjustable trackbar. (EDIT) this is the 2.5inch spring kit w/4shocks
before
after
before
after
That's only when both have TeraFlex coils in them. The coil kits will get rid of the factory rake. Now if you go with a spacer kit, the Rubicon will be higher.
