TeraFlex Rear Trackbar Bracket 2.5" BB
Old Apr 17, 2008 | 06:16 AM
  #61
bly109's Avatar
Originally Posted by windnsea78
NO WAY!!! Get an adjustable track bar for the front! The front bracket extentions increase the stress on the weld where the factory track bar mounts, breaking the weld off at the axle housing!! Trust me, get an adjustable track bar. Its worth it because you can fine tune for a lift, heavy bumper, winch etc...and they are heavier duty than stock. You can search the forum and you'll find the many breaks that the front brackets cause.
A front relocation bracket can also cause bumpsteer if a drop pitman arm is not also used to keep the steering geometry correct. Some larger lifts (4"+) use a heavy relocation bracket that strengthens the stock mount, an adj trackbar and a drop pitman arm to get the front axle centered properly.
Old Apr 18, 2008 | 10:02 AM
  #62
TeraFlex's Avatar
Sponsoring Manufacturer
TeraFlex only uses a front trackbar bracket on our 6" system. Otherwise it's just a adj. trackbar.
