What would you like in a snorkel design?
You are correct regarding the electronics and many other components that are prone to premature failure with water crossings.. This is designed to add that level of security that was not there before. I would be hesitant to offer an official number because of liability reasons... Don't laugh, they are amongst you ...
No modification or location change for the battery or fuse block will be needed.
As a side note..... How many of you (who do regular water crossings -mud holes) do service maintenance after each crossing, or do you figure the warranty should cover it?
Just asking a stupid question...
For others, RR can't post a number of inches, becasue that depends on your tires and lift as well.
can't wait till this drops, have the $$$ waiting for it.
Looks good, I was very excited at first when I saw the original drawings, but then kind of disappointed when I found out you wont be able to use a windshield mounted light with the high intake.
But....the intake has the 4 bolts on top, maybe you could fab up some kind of mount that goes into those 4 bolts that will allow us to mount a windshield light on top? Throw in a few rubber isolators/washers to prevent rubbing onto the snorkel and movement of light.
I think that would make people happy and more willing to buy the snorkel since many JKer's have windshield mounted lights.
If I'm wrong at least I would like this!! haha
Drew up a quick picture
. Sorry I'm not the best artist but hopefully the idea gets across. Made sure to use RR lights
I think thats a great idea dizk. While I was looking at your modified picture I noticed another issue I (and others) will have. The high intake snorkle is going to be tough to use with the Gobi roof rack. The front arms come down and bolt into the factory holes in the same place, and the Gobi's arms are very tight there so I dont think it would be easy to use both, maybe Im wrong, but I had to litterally hang on the side of my Jeep to pull the arms apart so the front light bar piece would squeeze on. But its like everything else, everyone cant have everything and I like the design of the low intake and safatri style low rise, So Ill make due. Again, good idea about the lights though.
I looked at the roof rack you have not sure what you could do since you said it was a tight squeeze. If possible I'd put the RR snorkel bracket under the roof rack bracket with maybe some padding so they wouldn't rub. I don't know if that is possible since you said it was a tight squeeze but it's the only way it could possibly work I think.
Basically, the way I have mine now is that the wire runs between the cowl and middle piece and under it into the engine compartment. I'd leave it like that but just add a little slack because the mount would be forward a little bit.
