The Staging Area Find out who's in your neck of the woods, discuss upcoming trail events or land-use issues and hook up with some great people to go wheeling with here. To make things easier for you, this forum has now been broken down into sub-forums that are area specific.
PLEASE DO NOT POST ITEMS FOR SALE IN THE STAGING AREAS
Sponsored by:
Sponsored by:
First Jeep!
Old Oct 23, 2012 | 07:54 PM
Cromer31's Avatar
Default First Jeep!
Hi there all! New to the Jeep world. I have a 2013 4door Sport. Want to run 33's with a 2.5" Teraflex or AEV coil lift. My concern is when adding front and rear bumpers with a winch is the weight going to sag the springs. If so what lift would counteract this?
Old Nov 30, 2012 | 04:28 AM
ThePalmBeachYeti's Avatar
My guess would be the old man emu heavy load setup, check it out mann
Old Nov 30, 2012 | 05:36 AM
OR-FAB's Avatar
Sponsoring Manufacturer
OR-FAB
I would think that you'd be fine
Old Nov 30, 2012 | 05:43 AM
deadman692's Avatar
If you do see a sag it probably won't be more than a .25". If the sag is more then that you could always add some small coil spacers to even it back out. Many companies take bumpers and winches into consideration when making their lifts. You might get more than the advertised height on stock bumpers and then once you add aftermarket bumpers and winch it will bring the height down.
Old Jan 15, 2013 | 05:47 PM
Cromer31's Avatar
What about going to 35". Regear or no. It's the 3.6 with 3.73 gears. Will it be ok.
Old Jan 24, 2013 | 08:28 AM
tiltz's Avatar
Yeah probably. I would install the lift and tires and see if the powerband is tolerable for you. Lots of people running around on 35s and even 37s with the stock gears and the pentastar.
I would also skip the 33s and go with 35s. Almost everybody that gets 33s eventually goes 35s. You wont have any clearance issues with the lift you are thinking about.
