The Staging Area Find out who's in your neck of the woods, discuss upcoming trail events or land-use issues and hook up with some great people to go wheeling with here. To make things easier for you, this forum has now been broken down into sub-forums that are area specific.
PLEASE DO NOT POST ITEMS FOR SALE IN THE STAGING AREAS
Sponsored by:
Sponsored by:
What's happenin? Disconnect question.
Old Jan 27, 2013 | 05:41 PM
Jesseb73's Avatar
Default What's happenin? Disconnect question.
Newbie from Waco here. Glad to be on the forum. I need some help. I just got a pair of JKS disconnects, the longer ones. I only have a 1.5" spacer lift and the directions say DO NOT USE INNCORRECT SIZE. I know the shorter ones are for 0-2" of lift and the longer for 2.5-6". My question is can I go ahead and install the longer ones? Why or why not? Thanks everybody for any accurate info you can send my way. SIC EM BEARS!
Old Jan 27, 2013 | 06:09 PM
Firelyle's Avatar
You need to have your sway bar roughly parallel with the ground (JKS states +/- 5*) so if you can adjust the ones you have to get you that setup, you should be ok.
Old Jan 27, 2013 | 06:27 PM
Jesseb73's Avatar
Does any one know what happens if its out of those parameters?
Old Jan 28, 2013 | 04:31 AM
Firelyle's Avatar
Worst case scenario - on a full flex the sway bar can actually spin around or invert and do major damage - not good. At a lesser degree I'm sure it has an impact on handling.
Old Jan 28, 2013 | 05:38 AM
Jesseb73's Avatar
That's what I was looking for. The chance for major damage or not. I'll hold off. Thanks again for the help.
