$900 later at the Stealership
Old Feb 6, 2009 | 03:05 PM
dlincoln91's Avatar
Default $900 later at the Stealership
so i had to take my jeep into the dealership today
brakes=shit
my rear rotors were torn up on the inside
all my brake pads had to be replaced
and 1 rear caliber went out
plus labor
no warranty
could have i gotten this stuff cheaper
Old Feb 6, 2009 | 03:06 PM
dlincoln91's Avatar
o yeah and they have to keep it until monday
Old Feb 6, 2009 | 03:10 PM
km2jk's Avatar
exactly why i do all my own work. thats probably about $150 in parts
Old Feb 6, 2009 | 03:13 PM
ccdjeep's Avatar
did they even use lube? Your getting screwed BIG TIME. Not only could you do the work yourself in your driveway or wherever there are plenty of brake shops around that can do that stuff at a fraction of the cost.
Old Feb 6, 2009 | 03:14 PM
dlincoln91's Avatar
i wish it was that cheap
Old Feb 6, 2009 | 03:21 PM
ccdjeep's Avatar
parts: sourced by rockauto.com
pads (all four) $107.78
rotors (rear) 37.79 apiece
caliper $76.79-core charge of $30 brings you to $46.79
total parts. $230.15
I'm sorry I don't see nearly $700 of labor there. See if you can't jerk yer Jeep outta there and take it elsewhere.
BTW there were cheaper pads than that so that price could be lowered as well.
Hope that helps! Good luck!!!
dlincoln91's Avatar
yeh i just found all the stuff besides the caliber for like a third of the price
Old Feb 6, 2009 | 04:37 PM
ccdjeep's Avatar
Caliper my friend. With a P.
Old Feb 6, 2009 | 05:51 PM
tambil68's Avatar
That type of work is really very easy. There is a new write up on doing the brake install.
Probably the only helpful tool would be the caliper compressor, kind of a bolt through a brake pad looking metal plate. As for rotors being torn up.. unless you were running metal on metal they shouldn't be. With the wheel off, just run your finger over the surface of the rotor and you will feel if it is badly grooved or "wavy". And if in doubt the rotor is easy to change and cheap enough.
You really don't need any special tools, just common wrenches etc.
Old Feb 6, 2009 | 06:10 PM
RedneckJeep's Avatar
In all my years, I have never seen any reason for a 900 dollar plus brake job. Seen plenty of them, but never a reason. .....I've been at it over 30 years, by the way. You got hosed. Sorry.
