08 JK U Joint???
Old Dec 17, 2008 | 11:56 AM
RevyJKU08's Avatar
Originally Posted by 2vpblaze
Hey guys, got a quick question. I did some trail riding yesterday and I have a feeling something isnt right. When ever I am driving down the street and I hit the slightest bump in the road I hear a thunking noise. I think its coming from the back. So my questions are, any ideas what is making this noise? Is it serious? And what is a U joint and what does it do?
Thanks guys.
It wouldn't be the famous Door thunk at the B-pillar? Some fixes is to adjust the doors or add some electrical tap to the door latch rings to tighten up the door from rattling around.
Also, have you looked at adjusting in your rear door latch ring, could be your rear door that is not adjusted in enough and causing the thunk...with the weight of the rear tire.
Old Dec 17, 2008 | 01:42 PM
2vpblaze's Avatar
Where would be the adjustments be for doors? I have no idea how to do that or what it is?
Old Dec 17, 2008 | 02:11 PM
wayland1985's Avatar
Perhaps it's the rear tailgate needing alignment too... Check to see that the black piece of plastic near the striker on the rear is nice and tight and aligned....
Old Dec 17, 2008 | 03:06 PM
ResQGrnRubi's Avatar
check the lugs on your spare, the B pillar was my first thought, search the stock forum. your shock bushings are really OK?
Old Dec 17, 2008 | 03:17 PM
2vpblaze's Avatar
I will take a look at those. Im not sure if the shock bushings are good or not. I dont know what I am looking for. From what my very limited vehicle knowledge intails it looked alright.
Old Dec 18, 2008 | 10:39 AM
2vpblaze's Avatar
What is a B Pillar?
Old Dec 22, 2008 | 11:00 AM
2vpblaze's Avatar
So I brought the jeep into the dealer today, and they fixed the problem. They told me some bolts were loose on the shoch and they had to replace the shock absorber. I am just wondering why did the bolts come loose? Is this usual wear and tear? And could I have done this on my own if I knew what the problem was?
Old Dec 23, 2008 | 09:07 AM
britjk's Avatar
Bad bushings.
