15K Service
Hey Guys,
I'm taking in my 2010 JKU Sport which has 14K for it's 15K service (I missed the 12K) anything I should ask for or ask that they don't do? Also what is it going to cost?
Currently I'm asking to have the following done:
Oil Change: (Free Coupon from dealership)
Recall work:
Drivers door knock
Passenger side door adjustment.
Loud rattle from the rear at around 2.5K rpm.
The latest CPU flash that everyone is talking about.
Thanks for your help!
Recall work:
Drivers door knock
Well the rattle is probably a loose heat shield that is right underneath you. It kinda sounds like it's coming from behind you when you're sitting in the jeep. Here's a link to a thread discussing it.
https://www.jk-forum.com/forums/show...ht=heat+shield
At 15,000 they will want to do the diff fluids. I believe they will rake you over the coals on the cost of that. It would be easier and cheaper for you to do that on your own, it's easy and there's a good write up on it on this website that you could follow if you've never done it before.
