2 door hard top
Old Jun 13, 2011 | 09:49 AM
jeepnyak's Avatar
Could somebody measure the length of their 2 door hardtop for me. I have a four door and found a two door real cheap w/0 glass. I am thinking about doing a cool half cab looking hard safari top if it's long enough.
Old Jun 13, 2011 | 09:58 AM
enzo319's Avatar
Originally Posted by jeepnyak
Could somebody measure the length of their 2 door hardtop for me. I have a four door and found a two door real cheap w/0 glass. I am thinking about doing a cool have cab looking hard safari top if it's long enough.
i would think the rear cab piece is identical, but then again this is chrysler and they like doing some funny stuff. i would think the only difference would be you need the 4 'freedom top' pieces. i'll measure my 2-door 2nite for you just in case.
what year is your jeep and what year is the top you are looking at? 07-09 tops are the same 2010 they changed how the front panels latched.
Old Jun 13, 2011 | 10:34 AM
jeepnyak's Avatar
It's a 2008
Old Jun 13, 2011 | 10:46 AM
rokklymer's Avatar
Which measurements do you need? I have an 08 and the hard tops off right now so it's accessible.
Old Jun 13, 2011 | 12:05 PM
enzo319's Avatar
I think he needs the caps dimensions. Front to rear
Old Jun 13, 2011 | 05:40 PM
rokklymer's Avatar
Okay measured it. I'm looking at the bottom and the full width at the front by the doors is 64 5/8. The wodth at the back where it starts to chamfer is 63 inches o/s to o/s. The distance from the front where the door is to the seam for the back section is 45 1/2 inches. Hope this helps!
Old Jun 13, 2011 | 10:14 PM
jeepnyak's Avatar
That helps, thank you.
Old Jun 14, 2011 | 07:24 AM
enzo319's Avatar
sorry about yesterday, i never had a chance to hook you up.
thanks rokklymer for the info.
do you need any other measurements?
This may b something that your interested in:
http://www.jeep4x4center.com/jeep-wr...-jk/skytop.htm
Old Jun 15, 2011 | 12:13 AM
jeepnyak's Avatar
I want to do something like this. This is jeepbronco1's sut build.
ID:	171946   Click image for larger version
Old Jun 15, 2011 | 07:35 AM
enzo319's Avatar
Ok so u wanna cut the top. Id hit up bronco on how he did his. Good idea tho. U can get a cover 4 the rear sorage area and u'd b set
