2-door power window switch question...
Old Apr 7, 2010 | 07:27 PM
changosurf's Avatar
Default 2-door power window switch question...
Hi, new to the forum...
question: does anyone know if the 'auto-down' (technically, i believe its called 'express-down') functionality for the OE power windows is integrated directly into the OE power-window rocker switch(es) (the switches that are mounted in the center bezel on the dash) ???
FYI, the MOPAR part# for the 2-door power window rocker switch that Im describing is '4602675AA'
Im trying to install power windows into my JK, using the OE hardware (window motor&regulator, center bezel w/ power window switch opening & 2-window rocker switch).
Id like to know if I'll get the 'auto-down' function simply by installing the OE rocker switch, vs. buying a regular aftermarket rocker switch and then being forced to also buy an additional 'power window control module' in order to get the 'auto-down' function to work...
can anyone confirm if the rocker switch itself is what controls the 'express-down' feature for the OE power windows???
Old Apr 8, 2010 | 02:44 AM
Coley's Avatar
I want to say that it's not at the switch, but likely in a module somewhere in the dash. I say this because when I use the express-down - once the window is all the way down I can hear a delayed click (sounds like a relay) somewhere in the dash.
