2 DR front seat(s) FOLD & TUMBLE
I just looked at the jeep website and they list a "Easy Access Passenger Tip-and-Slide Seat". does anyone know if the 2dr passenger seat acts differently than the drivers side? just a thought.
Eternal ***erator
On the passenger side, on the right of the seat (if you are seated in it, near the door) are two levers. The lower horizontal lever (the one attached to the base of the seat) adjusts the recline angle of the seat back. there is an upper lever there too that is more verticle (it is on the side of the seat back). When you press the second lever to the rear of the vehicle, it flips the seatback forward, and releases the seat base at the same time, so the back flips forward, and the whole seat slides forward. about 6 inches i think, it aint much, but it lets me get in there. The drivers side seat will move forward and tilt forward too, but you must do both actions seperately with their respective controls. The passenger side one does both with just the one lever.
Whn you are done on the passenger side, push the top of the seat towards the rear of the vehicle, it will go back to the reclined angle it was at previously (i think) and slides backwards at the same time, although it wont slide to where you had it set if you originally had it set all the way to the rear.
It is an attempt to make access easier. it helps, but it still sucks.
Hope this makes sense.
for me i tried to get the pasg. seat as far forward and there was only about 2-3 inches from base/back of seat to the back of door opening
thats not enough to get a normal size shoe through, this just seems wrong! there is a big difference compared to the TJ
it's a saftey hazard if your a Nader type, your friend gets out of the back seat, gets there foot stuck in between seat and door frame and falls flat on her face
even cheap econo box 2 door cars give enough room to get your foot through
I will have to try on another jk 2dr just to be sure
Yeah, its way way more dificult than the TJ is. I think its to push people into the 4-Door. Its certainly making me wish I had gotten the 4-door, just from hauling baby. If I could trade up without taking a bath, I probably would. But I know I'll lose my shorts on the depreciation.
I just noticed yesterday that while it's a bigger pain to move the driver's seat, it's easier to get in from there. Apparently they decided to attach the seat belt to the seat on the passenger's side, but to the floor on the driver's side. Brilliant!
Eternal ***erator
WTH would they do that?
Guest
Posts: n/a
1. New longer-travel seat base rails that allow the passenger seat to go as far forward as possible. This will free up a couple of valuable inches in the space behind the passenger seat for entry/exit.
2. Floor anchor for the seat belt.
Any thoughts?
