2 Dr JK - Seat won't fold & slide for rear passenger
Old Jan 29, 2012 | 12:20 PM
  #31
carnut08's Avatar
Originally Posted by robbiegsic
Just wanted to say thanks as well. My 2dr 2011 JK needed this pin reset and it fixed it immediately.
See my post above yours. Be prepared to do this again and often. The design is faulty.
Old Mar 13, 2013 | 11:22 PM
  #32
Paul Woodcock's Avatar
Hi Guys
Thanks carnut08.
Printed the picture, went to Jeep with torch and long flat screwdriver.
Fixed in 5 min.
I have a 2012 model (non US) and have these tilt, slide & rise type of seats on both sides.
I had spent 30 min trying to figure it out earlier in the day.
Goto love this forum.
Regards
Paul
Old Apr 6, 2013 | 09:08 AM
  #33
Mike Davis's Avatar
Has anyone come up with a mod to move or tilt an 08 2dr seat style further forward for rear access? The aftermarket companies are leaving it alone due to the liability.
Old Apr 7, 2013 | 06:12 AM
  #34
genesbro's Avatar
I think best bet for us with the older style might be to find one at a salvage yard out of a wrecked model 11 or newer. I removed my rear seat after seeing how hard it was to get back there with the poor design of the pass seat slide. I like the extra room that gives me and don't have any kids at home anymore and don't need to carry more than one pass anyway so works for me.
Old Jan 13, 2015 | 01:46 PM
  #35
jasonbfrench's Avatar
Default Pin location
Originally Posted by carnut08
Problem solved. The pin that engages the remote release inside the the outermost seat rail had slipped out of its slot.
Another Jeeper told me the secret. It's not a difficult fix to re-set the pin, but it is in an awkward location.
Thanks to all who responded!
Hi, any chance you have a picture of your fix? Same thing happened to me.
Old Jan 13, 2015 | 05:45 PM
  #36
Just in joy's Avatar
check page one or 2 he posted photos on already
Old Dec 2, 2021 | 11:50 AM
  #37
Andy uk's Avatar
Default 2013 jk sahara
Originally Posted by terribad16
Good to hear the OP got the problem solved.. But I'm a little confused on what the 07 can't do? I have an 07 and with just the one lever on the side of the seat the seat folds forward and slides to the dash... It doesn't tumble forward but none of the JK's do that do they? So Idk if I have a special 07 or everyone elses is broken but my 07 does fold and slide for...
yep my 2013 jk sahara front passenger seat stopped the tumble mode today, it worked last week, so il have a look at what iv just read about that pin, cheers all
Old Nov 13, 2025 | 04:16 PM
  #38
brotherj4mes's Avatar
I had the same issue as OP but the problem was not the pin, it was actually the housing...
It ended up being that the cable housing was not properly seated near the tumble lever itself at the back the seat. The cable and housing were just flopping around when the tumble lever got pressed. If you've ever worked on bike brakes you'll know what I mean: If the end of the cable housing isn't kept stationary as the cable is pulled, the cable action doesn't work. Once I found the little slot that the end of the housing sits in, the tension in the cable was way greater and the tumble and slide worked perfectly.
Old Mar 23, 2026 | 08:22 AM
  #39
NapkinTaylor's Avatar
Do you have any pictures? I'm having the same problems.
