2 radiators?
Old Dec 16, 2011 | 05:11 AM
Guardguy's Avatar
Default 2 radiators?
I have 2 factory radiators? One is the regular aluminum color you would normally see on a vehicle. The other is black, maybe 2 inches narrower but the same height and sits in front of the regular radiator. Is this just part of the regular radiator or a transmission cooler? 2008 JK X with automatic, no towing package but does have the preferred package that comes with heavy duty suspension.
Old Dec 16, 2011 | 05:21 AM
goawayfarm's Avatar
Condenser for the air conditioning........
Old Dec 16, 2011 | 05:25 AM
Guardguy's Avatar
Thanks! I guess I was hoping too much for a factory transmission cooler.
Old Dec 16, 2011 | 08:55 PM
profebill's Avatar
it also a transmission oil cooler. the two bottom tubes are for the transmission. just lay on your back underneath and look up. you will see two lines going from it to the transmission. it is completely inadequate. you need to go to autozone or where ever and buy an auxiliary oil cool and install it. is a very simple easy quick cheap thing to do.
