2008 Jeep JK burning oil
Old Nov 18, 2013 | 04:20 AM
Cats&Jeeps's Avatar
Putting a Stop to Oil Consumption through the PCV Valve
Background Info on the PCV System The PCV is an emissions device that allows the pressure and corrosive gasses in the crankcase to vent, without venting these harmful gasses to the environment. The directional valve is in place to prevent a backfire from spreading to the crankcase. In the event of a backfire into the intake manifold, the PCV is supposed to seal shut, preventing the flame front from traveling into the crankcase. Without this directional valve in place (and fully functional) a backfire could also cause a crankcase explosion. All motors will experience some degree of Blowby. Even a freshly rebuilt motor can experience between 5-10% Blowby, as checked with a Leakdown test. (Blowby is not the only source of crankcase pressure however. Due to the reciprocation of the pistons there will be a build up of pressure due to the air not being able to flow as fast as the pistons are moving in the higher RPMs) Blowby of combustion gasses introduces fuel and other combustion by products into the crankcase. Raw fuel, moisture, and various acidic materials will all contaminate the engine oil. Moisture can also enter the crankcase due to condensation overnight. The good news is that most of these contaminants are highly volatile, meaning they will vaporize at relatively low temps; around 200F. Once these contaminants and moisture have volatized though, they must be purged from the crankcase. This is where a crankcase ventilation system comes in. In the old days the crankcase was vented to the atmosphere via a hose that ran under the car or into the exhaust. The downside to this is that these volatile materials were being introduced to the atmosphere, increasing environmental damage. Now a Positive Crankcase Ventilation system is in use. In a positive venting system the crankcase contaminants are purged into the intake manifold so that they can be burned in the normal combustion process. This is very effective at reducing the amount of unburned HCs that are released to the atmosphere. Troubleshooting Your Oil Control Issues The first step is to find out where the oil is coming from. Pull the Throttle Body/Valve Cover hose from the TB. If it is wet with oil then this is an entry point. The normal causes of this are excess Blowby (which needs to be ruled out with a compression test), or the VC baffle has been removed for rocker clearance. Just looking down the oil filler neck should reveal if the baffle is in place. If you see rockers, then it is time to get creative and fabricate a baffle. If there is no baffle but the TB/VC hose is bone dry then you may be able to get away without using a baffle. Next pull the PCV hose. Again if it is wet with oil, this is an entry route. A quick fix for this is a separator from Steeda, Home Depot, or Lowes. For about $25 (The Steeda unit will be more expensive) for the separator and fittings you will be able to remove most of the oil before it gets to the intake. Also, you need to verify that the PCV screen is in place. This often forgotten part is located underneath the PCV in the back of the intake, and helps remove oil mist from the crankcase gasses. Contributed by tmoss... www.tmossporting.com I have seen a BUNCH of intakes (100s) and you can tell the lower intakes that were on cars whose PCV screen had been blocked - they have a very thick coat of grime on the bottom of the lower intake. You know the heads had a nice thick coat below the rockers too as the blow-by had no where to go. When you put the intake in a solvent tank and wash it, it does not cut all the crud off - reason? - the blowby gasses will not come off with safety solvent. why, I don't know. Do your self a BIG favor and install a PCV screen once a year. If a compression test comes back normal, and the above mentioned lines are dry, then the valve guides are suspect. The PCV Problem Many of the Fox Body Mustangs seem to have serious issues with oil consumption through the PCV or Throttle Body/Valve Cover line. There are 3 main causes of this problem. 1. Excessive Blowby 2. Removing the Valve Cover Baffle at the oil filler neck 3. Removing the Baffle and/or the PCV Screen on the lower intake However, in some head/cam/intake (and possibly stroker) combinations the problem can persist. Sometimes a small oil/air separator can be used to help filter out the oil before it gets to the intake manifold. Most who run this setup will remove the small plastic filter, as it tends to plug up and restrict airflow. An oil/air separator is a band-aid solution though, and should not be considered permanent. The goal should be to completely eliminate the flow of oil from the crankcase. Theory The problem seems to be that the stock PCV line does not flow enough volume to allow adequate ventilation in modified motors. The lack of volume flow creates a build up of pressure in the crankcase which forces crankcase gasses through the PCV at higher velocities. With the added velocity the crankcase gasses are able to pick up more oil vapor; carrying it into the intake manifold. Yet another issue is that the stock single PCV system can create rather long flow paths for pressure to vent. For example gasses in the front of the crankcase would have to flow to the back of the block to exit through the stock PCV. The result of a long flow path is that it will take longer to purge the crankcase pressure. Solution The solution is to allow a greater volume of gasses to vent from the crankcase, at lower velocities. This can be done with a larger ID PCV hose and PCV, or by adding a second PCV line. Since larger ID PCV valves can be hard to find the easiest solution should be to add a second PCV line to the drivers side valve cover. The stock drivers’ side valve cover can be replaced with any valve cover that has an oil filler/breather hole. What valve cover is used does not matter, so long as there is a way to mount a PCV valve to the valve cover. A stock passenger side valve cover installed on the drivers’ side would work well, or many of the aftermarket valve covers have holes intended for mounting breather caps. The hose from your new PCV should flow either directly to the intake manifold (parallel to the stock hose), or merge with the stock hose. An air compressor oil/air separator can still be used to filter out any oil that does get out of the crankcase. However, if the system is setup right and the motor is healthy, there should be very little oil accumulation in the separator if any at all. Secondary Benefits The increase in the volume of air that can flow out of the crankcase means lower accumulations of harmful Blowby gasses and moisture. Also, lower crankcase pressures will allow greater efficiency and power (although this affect is probably minimal on a street car). More Notes on Installation 1. It may be better to install the drivers side valve cover PCV toward the front of the motor. This will allow a shorter path for gasses that are trapped in the front of the crankcase. 2. It may not be a good idea to install a third PCV on the aft side of the passenger side valve cover, as this could allow fresh air from the TB/VC hose to vent directly out that PCV. This would result in no fresh air hitting the crankcase, and a greater accumulation of harmful crankcase gasses and moisture. Extra Notes From what I have seen, the oil accumulation in the intake will be greatest when the car is left to idle for some time (stuck in traffic or idling in the driveway), and then with some rpm the oil is picked up and thrown into the combustion chamber. If you live in a humid part of the country, or see a fair amount of condensation on the ground in the morning, then you will most likely notice some moisture in the separator, resulting in the easily recognized brown milkshake appearance of the oil in the separator. This is fairly normal, as overnight condensation will form on the inside of the engine block. Once the oil gets up to temperature, this moisture boils off, and collects in the separator. This is a picture I took of my engine at its worst. The car had been at idle for several minutes before I shut it off. http://forums.stangnet.com/attachmen...8&d=1123979745 This is a picture of my current setup. http://forums.stangnet.com/attachmen...3&d=1149575196 Hope this helps some, References: http://www.steeda.ca/catalogue_product_type_918.asp Home Depot Fram PCV Screen - # BA8113 NAPA PCV Screen - # 6978 Napa PCV - # MPF39203 / CRB29203 Fram PCV - # FV198 Purolator PCV- # PV98C Borg Warner PCV- # PCV203
Old Nov 18, 2013 | 04:23 AM
Cats&Jeeps's Avatar
Oh and by the way Chevy finally fixed this issue in the LT1 engine with a factory oil catch system built into the pvc intake housing... Research the fix.... Engines are engines ford Chevy Chrysler etc...
Old Nov 18, 2013 | 05:49 PM
Ryan0260's Avatar
Catch cans are a great idea for those with consumption issues. It will allow you to monitor how much oil is blowing by, and recycle that oil as well.
Old Nov 19, 2013 | 04:19 PM
JeepJeepster's Avatar
So you all are saying we should be getting more then 3 qts in this catch can?
Has anyone done this and found that much oil in the catch can? Ive read up on catch cans and know their purpose, but Ive never read about someone catching much more than a few cups of oil...
Old Nov 20, 2013 | 04:50 PM
Ryan0260's Avatar
No, but you should them often. If you are losing that much oil, you have a serious issue.
Old Jan 10, 2014 | 08:24 PM
Corb's Avatar
Originally Posted by Ryan0260
Many deal with this, and the oil consumption test is always the place to start. They should have also changed the pcv valve. Are you still running 5w20? If so, go with something thicker like 5w30 or 10w30. The pinging is also common with this issue. Try to run some Mopar CCC to try and clean the valves up some.
What is Mopar CCC?
Old Jan 11, 2014 | 05:20 AM
karls's Avatar
Mopar combustion chamber cleaner
Old Jan 11, 2014 | 02:30 PM
nismosis's Avatar
Hey everyone, nice forum youve got here. My GF has a 2008 Jeep jk thats using a considerable amount of oil. This jeep was bought brand new in 2008 and has always been driven on the street at an easy pace. Pretty sure Ive never seen the rpms go over 3,000 before. Oil has always been changed at a 3,000 mile interval. I've read on several forums about the jk using oil but Ive yet to see a common solution nor do I know what the solution is. In the beginning of this year (2013) I noticed her Jeep was low on oil. Didnt think much of it but I topped it off. When the time came to change the oil, it only had around 4 quarts of oil in it. Cant remember the mileage when I topped it off or anything. We took it to the dealer and they did their little oil consumption test. They always fill it up right to the top of the safe zone on the dipstick, which I think is high but whatever. After 1,500 miles it had used over 2 quarts of oil. Found out at that time that it had the life time warranty, so they put a new (reman) set of mopar heads on it. Also at the time, it was leaking antifreeze something awful. It would leave a large puddle of antifreeze everytime she parked for over 30min. The puddle would be at the rear of the engine and I couldnt for the life of me figure out where it was coming from. Anyway, they changed the heads and the oil consumption SEEMED to slow down. The antifreeze leak stopped so I assume it was the intake manifold. Fast forward to now, its using antifreeze again and using oil again. No puddles of antifreeze but its using it much slower than before. Took it several months to use whats in the overflow tank. Ive noticed this engine rattles like mad under load. Going up hills and accelerating it rattles, sounds just like pre-detonation (pinging). After they replaced the heads it stopped rattling. They said the oil is being burned b/c of worn out (bad from factory) valve guides. Which in turn ruins the valve seals. No smoke is ever seen, even on startup. I know, the cats burn it off. At start up a cat is cold and will not burn off the smoke so if the valve seals are bad it should smoke at startup. Would bad valve guides cause the valves to rattle? The rattle returned soon after the new heads were installed(~1,000miles or so later). No leaks are seen anywhere. Today they replaced the water pump, they say thats why the antifreeze is disappearing. Never seen any leaks from the water pump but hey, its free. They did another oil consumption test and say its not using enough for Chrysler to do anything, which I understand, they wont get paid if its not using whatever amount. At 2,500 miles the oil was between the bottom of the dipstick and the bottom of safe. I thought for SURE that would be enough to get them to continue working. I would think that would be more than 2 quarts but idk. Just sharing my experience, any input would be amazing. Ive yet to check the compression but I do have a compression gauge so I may do that. May try to do a leak down test also. The dealer says not to worry with it, they didnt say to let it run out of oil but they said "hey, if anything happens Chrysler must fix it." Theyre great people to deal with. For those of you that say, "check your oil every day, using some oil is normal." You're idiots. Plane and simple. No engine should use oil with this many miles. My family has had jeeps since 1994, and I still drive that 1994 Jeep. Its a 4.0 zj with 201,000 and it uses absolutely NO oil. My kj uses no oil, my 5.9 zj uses no oil, my brothers 99 xj uses no oil, my brothers srt8 wk uses no oil, my moms 06 wk Hemi uses no oil, heck my dads 96 honda accord with 250k uses no oil. Good engines do not use oil. Jeep currently has ~76,000.
Hi. My 08 Sahara is currently going through an oil consumption test at the dealer. I too noticed she was drinking oil. I get my oil changed every 5000 kms. Before my last one I happened to check it myself, it wasn't even reading on the dipstick!! Henderson the test. The problem is up to and prior to 08 the bottom ends of the motors were made in Mexico, or something like that. The problem was discovered and changes were made. It's no longer an issue. So those of us that have an "old" motor have an acceptable limit of oil consumption. Our jks are allowed up to 1 liter lost per 1600 kilometers. Crazy eh. So nearing the end of an oil change time it's critical to check your oil. If you are losing more than this then the warranty will cover the new bottom end. Providing you have warranty left. Anyways I hope this helps, my details could be a little off, but it's all info right from the dealer. Hope that helps!
Old Jan 12, 2014 | 06:01 PM
VancouverRubi's Avatar
I have an 08 Rubicon, I change my oil every 5000km. Every oil change I do I use 5 quartz of 5W20 Quaker state. Just changed my oil today and put the oil back into the jug it came from and it measured 2.5 quartz.
Old Jan 12, 2014 | 06:12 PM
Jiblet's Avatar
How many km on it?
Is that the first consumption you've noticed?
Have you changed the PCV valve yet?
Probably a good idea to check the dipstick every 500km or so.
