2008 Wrangler Unlimited X Problems - huge amount; right now the Seat Belt Retractors
For later readers - It took a few weeks of continuous searches, but I finally found several retractors on Ebay at the same time. Prices varied from $70 to around $200, and a wrecking yard nearby accepted my offer of $100., shipped. I'm till waiting for a good day to install it - I have a 6 month warranty.
Ebay is not the steady marketplace it once was. Many Sellers aren't putting up with the steady line of BS Ebay is putting out, and wrecking yards aren't bothering to put up every item they have. You can always ASK based on the pictures of the wrecks they show in the listings.
Also - and this is the BEST ADVICE - check YOUTUBE for instructional videos of repairs you need. There are TONS on this subject and most others you can think of. It's the best resource when you sun into a problem - like the upper door post seatbelt mounting
My 2008 JKU has probably had 5 or 6 axles of brakes replaced, and the dealer was always clueless. There has been no reason to when the calipers would freeze - but I'd always be warned by brake screeching beforehand. I have no proof of ANYTHING, but I can tell you that since I stopped using the dealers for repairs, the problem has stopped (I hope!). I can only think the "non-dealer" repair shop I am now using didn't use MOPAR parts. I had begged the dealership to use something other than MOPAR, but they refused.
Just sayin'
Just sayin'
I have 2008 X as well and yeah, the front seatbelt retractors are garbage. Every time you take a belt off you have to "help" the belt back up into the retractor or else the belt/buckle etc. gets slammed in the door (has happened many times)...I have been told the manufacturers use lowest bid parts and this sure makes me a believer.
the latest is that the roof leaked and the seat belt retractor rusted that bad in the "do not open" side.
In other words, your top leaking doesn't make your particular JK a lemon, it just makes it an ordinary Jeep.
Now regarding the seatbelt, you might get it replaced for free. Typically seatbelts are required to have a lifetime warranty. I have had them replaced for free on several cars.
#2: burns a quart of oil every 800 miles.
#3: each caliper locks up at least once per year. AutoZone keeps giving me new calipers and pads.
#4: related to #3, rotors
#5: check engine light comes on and off all the time. Sensor 2, bank 2.
#6: roof is hard / shot. Can not use zippers.
#7: key fobs virtually impossible to replace. I am down to one. I was told that I need both original ones in order to program one new one! Well I can't find one of the original ones! I am down to one.
How do people live with these pieces of shit? I love my 1949 CJ3 that I rebuilt in 2007, but am in a love and mostly hate relationship with this 2008 WranglervUnlimited X.
BTW I have no input regarding an AT linkage thing.
So, try this:
- get some original Mopar calipers even if they are used/junkyard and rebuild them properly. Get rotors from NAPA (not AutoZone). I bet your brake problems go away. Then stop fixing what ain't broke. When the pads wear, replace the pads, and leave the rotors and calipers the heck alone (don't turn the rotors... no reason unless they are somehow damaged, in which case just replace with more new NAPA rotors).
- inquire about warranty on the seatbelt. Safety equipment ordinarily has lifetime warranty.
- replace the faulty catalytic converter. Don't ignore the CEL. This is not just an instrumentation problem. It's a real broken thing.
- replace the top and understand the cadence of soft top replacement. It's a convertible. If you don't like this wear/tear then get a hard top.
Things you will have to put up with because of Jeeps kind of crappy (real) quality: oil burning on old/high-mileage engine, only solution is new rings; top leaking, you might be able to improve it with a seal kit (that foam stick-on stuff that wears in like a month) but if you take the top up and down it'll eventually leak again. Put a hard top on it and make it stop leaking one time, then leave the top in place, it may not leak again. But it's a horrible design and all but guaranteed to leak, sorry to say, you know, "it's a Jeep thing, don't bother trying to understand".
I doubt that CJ3 has a soft top that doesn't leak or an engine that doesn't burn oil, BTW. Or disc brakes, a catalytic converter, retractable seat belts, etc. It's apples to oranges. My '92 Suzuki GS500 has more in common with a modern Jeep than your old Jeep does. Hardly fair to say "the soft top leaks on my Jeep but I never had a problem like that with my motorcycle..."
I got a retractor /belton Ebay for $100, used. As said, check YOUTUBE for instructions.
I've had the brake problems, but none since I stopped using Mopar parts.
The other issues are news to me. I use 1 quart in 3500 miles at 112,000. That's not to say I haven't had what I think is more than my share of problems.
I hope thing improve for you.
Honestly, when I look at that list, it's a 10 year old vehicle and every vehicle will need maintenance repairs. Sounds like someone purchased a used JK and expected it to be in new condition after 10 years of use.
Bank2, Sensor 2. That's the exhaust O2 sensors. They don't last forever. Had to replace my post cat O2 sensors at 90K miles. Not an expensive part to replace.
Brakes/rotors. They're wear items. Replace with a good brand or OEM you will be fine.
Key fob, hard to blame the Jeep for you losing a key. Yes, you can program your own if you own 2 fobs and will cost $20 for a backup. If you only have one, then you can go to a dealership or auto lock-smith to have a 2nd programmed for you but will cost more. Pretty common among all cars.
Trans linkage? It's 10 years old, go visit Youtube it's a simple fix.
Oil burning? It is a 10 year old vehicle. The PCV likely needs to be replaced which will help with that problem.
Soft top problems? It's 10 years old....they don't last forever. I have the dual top option, soft top usually only sees 2-3 months of the year. Mine is 9 years old and is still in great condition. If you have only the soft top for 10 years, that's the problem. Read up on other convertibles and see how long those tops last. Go get yourself a replacement or look into getting a hard top and never worry about it again.
Seat belt problem due to driving in rain? Don't drive in rain with the top off. They're not meant to drive in rain with the top off. Pay for the repairs now that you did.
That entire list are all pretty simple maintenance repairs. If they happened all at once it probably seems a little overwhelming but with a little time/effort they're all easily repairable.
