2009 JK using oil????
I have an issue with my JK using oil? Is it possible?
It is NOT burning it, my exhaust smells normal It is NOT leaking/dripping from engine It is NOT in my radiator fluid and it is NOT making any noises even tho it ran almost 4 qts low.. The idiot lit never came on. I thought my newer JEEP would be good. Since my boyfriend put the oil in to top it off is used about a qt in a week.... |
I know my jeep burns a shit load of oil its a 07 hmm maybe you have a small leak or something
I have the check my jeep every 2 weeks
Try using 10w 40 and run 89 octane gas. There's a thread on here about a guy doing this and his jk doesn't burn oil anymore
Originally Posted by bob-o
(Post 3353145)
I already run the 89 octane. Hmmmm Jeff used 5/30 oil last change. It didn't seem to use oil before. Will this issue just suddenly begin?
WTF does 89 octane have to do with this? That's a knock inhibitor. Knock comes from pre-detonation. Pre-detonation comes from the combustion of the contents of the cylinder igniting while the piston is traveling upwards. She could run racing fuel with 110% octane and its not going to change a thing.
She's either burning from bad rings, bad head gasket, or pcv. Uggh....:doh: |
What he said was change your Pcv and put a heavier weight oil in. Try 10-30 and see if it gets better. If your still under warranty I would take it to the dealer and get an oil consumption test done. For any other answers use the search button as this topic has be beaten, buried, dug up, beaten, had sex with, left at the alter then murdered over and over again. Remember it's always fixable, it'll just take money. ;)
^Solid advice. You are not the only one, search 'oil sucking 3.8' you will find a lond thread on the topic.
Originally Posted by Jeepergurl67
(Post 3353131)
It is NOT burning it, my exhaust smells normal It is NOT leaking/dripping from engine It is NOT in my radiator fluid and it is NOT making any noises even tho it ran almost 4 qts low.. The idiot lit never came on. I thought my newer JEEP would be good. Since my boyfriend put the oil in to top it off is used about a qt in a week.... Don't wait for the idiot light, it only measures pressure and if it comes on... uh oh! Sudden onset makes me think PCV. |
