2010 Engine Issues?
Old Nov 15, 2010 | 05:40 AM
mcgill2634's Avatar
2010 unlimited Rubicon. 26000 km on jeep, 3000 km on new motor. Massive oil consumption when the old motor was pulled. Was told by service manager that jeep is using a new part number on the replacment motor and in his 25 years as a jeep guy a new part number means jeep fixed an issue. None the less I love my pile of junk jk, I'd buy it again.
Old Nov 15, 2010 | 03:15 PM
Stonewhite JK's Avatar
How is your oil consumption now with the new motor?
Old Nov 15, 2010 | 03:45 PM
JeepaRoo's Avatar
my 2010 SIlver JK with 4100 miles is showing signs of having water in the oil... made an appointment for service so we shall see if its real or just my imagination...
but my coolant level is showing low.. my oil level high and a nice swirly foamy hot chocolate look to the oil... usu == bad news..
my previous 2 JK's never had any engine mechanical issues
-Christopher
Old Nov 16, 2010 | 09:59 AM
ToolManTimTaylor's Avatar
-Christopher
That and a Head Gasket
Old Nov 16, 2010 | 10:22 AM
txnightwheeler's Avatar
Originally Posted by BlackNorthernJK
I have an '07 with 45,000 miles, no oil issues, no knocking at startup, no spun bearings. Food for thought.
Agree i got a 09 39 thousand miles or so and have not had any oil problems the only reason i took it to the shop was to get the flat tire fixed other than that no problems on the jk
Old Nov 16, 2010 | 03:55 PM
crwood1's Avatar
Default 2007 Rubi Unlimited with 70k
No abnormal oil consumption about 1/2 cup each 1000+ miles--10-30 Royal Purple from 3000 miles--Power One permanent oil filter has 17 lb relief valve, no noise on start-immediate pressure, installed oil pressure and temp gauge at same time as filter-CRW
Old Nov 16, 2010 | 10:42 PM
Peter01's Avatar
May 2010 delivered.
9000km on the clock.
No signs of oil use at present.
Checking every Sunday before fuel up.
Fingers crossed.
Going in next month for its 6 month/12000km service.
Old Nov 17, 2010 | 03:47 PM
birdiecat's Avatar
Originally Posted by JKlad
I do know (as posted here on this forum) that several JK owners who have either had spun bearings (due to the sump running dry) or high oil consumption have found, upon their motors being pulled down for investigation, that both compression rings and oil expander rings on the pistons had been installed incorrectly at the Mexican engine plant (compression rings with all the gaps lined up, & oil rings intalled upside down). I suspect that that these incorrectly assembled motors were limited to a few batches before quality control identified the problem and fired Gonzales the line worker for being smashed on tequila during his shift (a reasonable scenario considering relevations that workers at their US plant were getting drunk and stoned on their lunch breaks).
The fact that Chrysler covered the cost or half the cost of re-build/replacement of these motors even when out of warranty (according to the people who posted their experiences here) suggests that Chrysler is well aware of the problem. Hopefully this means that they have already dealt with the issues at the plant, so that motors rolling of the assembly line now should at least have their pistons assembled correctly.
Certainly anyone with a spun bearing or extremely high oil usage should have the motors pulled down and all findings documented, even if they have to pay for it themselves. The evidence of incorrect component assembly can then be used in evidence; I'm sure Chrysler would come to the party quick smart when faced with this if they are not being co-operative.
Having said all that, I agree with others that the spun bearing issue is not, based on percentages, a common problem. In comparasin, an example of a statistically common problem with JKs would be steering clunk due to faulty steering boxes/intermediate shafts, which it seems a large percentage of owners (myself included) have or the issue of overheating automatic transmissions.
just a thing about the piston rings, i build engines for a living and compression rings rotate on the piston so rings lining up and staying that way doesn't work for me and oil rings up side down i don't know i could be wrong
Old Nov 18, 2010 | 10:45 AM
humdezign's Avatar
My 2dr 2007 is dead my post. I'm told by the dealer that I need a whole new engine at about 6 grand symptoms point to oil issue and possibly spun bearing.
Old May 23, 2011 | 07:44 PM
mcgill2634's Avatar
10000 km on the new motor and is hasn't burnt a drop. I'm thinking jeep whatever the issue was, dealer said when they ordered the motor it was a new part number. They suggested that the new part number means jeep has fixed whatever issue there was with the motors.
