2010 Soft Top Differences
Old Dec 23, 2009 | 02:38 PM
slugbug's Avatar
Default 2010 Soft Top Differences
Can somebody out there please explain to me the difference between the 09 softtop and the 2010. I'm about to order a 2010 sahara and i'm not sure if I want to order the softtop or not. If it's a lot better than my 2008 (which works fine to me) I might pull the trigger on 1. If it's close, I'll just buy someone elses off them and save half the cost. All I know is that they have springs on the frame behind the back row seating to lift it easier. thanks guys, oh ....and girls
Old Dec 23, 2009 | 03:36 PM
Brian08JK's Avatar
Instead of plastic clips for the window frame it uses cables. and it is supposed to be an improvement.
Old Dec 23, 2009 | 05:15 PM
MACE24's Avatar
Default There is still some wind noise
I have a 2010 soft top Sport Unlimited...build date of 10/09
Disclaimer...my last JEEP was 1998 TJ Sahara
That being said...from day one picking up this 2010 JEEP with 4 miles on it...there has always been a annoying wind noise from the PAX side head liner/window area...BUT no water leaks!
Tomorrow, I'm gonna tighten up the pillar and sun visor connections, and install some weather stripping, where there is a open space between the A-pilar and dash board
I do want to say this JEEP/Soft Top has a lot better fit and less wind noise then said mentioned '98 TJ Sahara
Old Dec 24, 2009 | 05:34 AM
CitadelJeep04's Avatar
Just buy your Jeep with the hard top, wait 6 months, and buy a 2010 soft top off a member for like $400...
Old Dec 24, 2009 | 06:04 AM
wolfpuppies3's Avatar
Default No hardtops to be had from the factory, if you can find one
on the lot you are good to go.
Old Dec 24, 2009 | 04:31 PM
bluerubicon08's Avatar
Most of us with the '07, '08, '09 model soft top have had nothing but trouble with them leaking over the door handles on both sides. It was a bad design from the get-go. Chrysler has TSB's to add some foam, but that fix rarely works. They realized it was a bad design and have re-designed for '10. IMO they need to do a recall on the previous tops.
Oh, by the way, after 4 trips to the dealer, they finally forced Chrysler to put on a new top! Pearson CJD in Richmond VA is the BOMB. One of the few good ones out there!
Old Dec 25, 2009 | 05:53 PM
Phantasm's Avatar
Vet: Army
I took a look at the 2010 soft top, was able to slip my fingers up inside the cab under the magetic? strip along the top of the door. I doubt that will hold up over time at highway speeds. I didn't get a chance to open it up to see how easy it is to do open up. But, I prefer my top that tucks under the door jam. Is it harder to open? yes! That's what I like about it, the minimal secuirty I have, it increases it that much more.
