2011 dashboard??
heres what ive found so far
First you have to remove a total of 4 screws. The panel under the steering wheel just pulls off to expose 2 of these screws. The third screw is behind the power window panel in the center of the dash. (If you dont have power windows I think its just a cubby) Remove this panel by pulling out to expose the third screw. The 4th screw is under the plastic mat in the console on top of the dash.
Once you remove these 4 screws the dash just pulls off. You have to unclip the power supply to the power window panel in order to remove the dash.
The screws have the hex head so a socket set is necessary.
