2011 Jk Sport with O2 sensor readings in all 4 sensors
Stock JK TechBulletin board forum regarding issues with OE (original equipment) components of the Jeep JK Wrangler (Rubicon, Sahara, Unlimited and X) such as factory suspension parts, engine, transmission, body parts, interior fixtures and the on-board computer.
Hi people, I just adopted a 2011 JK Sport (from my fiance) and I have codes in all 4 oxygen sensors (heater circuit codes, P0135, P0141, P0155 and P0161). The jeep has 68,500 miles on it, so I replaced all 4 sensors just for maintenance. There was only 1 sensor with a faulty heater circuit that measured around 45ohms. The other sensors
were good. I have the same codes after I cleared and replaced the sensors. Does this jeep have an oxygen sensor fuse? Is there a ground wire issue in this model? Any help will be greatly appreciated, thanks.
Hi, I checked the ground terminal of one o2 connector and there was continuity to ground on the engine block. Now, can someone confirm if I turn the ignition switch to the on position without turning on the engine would that send +12v to the oxygen sensors? Because I have 0V at the sensors when I just put the ignition key on. I didn't turn on the engine since the connector is close to the exhaust and don't want to get burned. Any help will be appreciated. Thanks
I just checked for voltage on the O2 plug by turning on the engine and there is voltage (at least in the one sensor that I checked). I now believe its the pcm. Any thoughts before I buy one? Thanks
