2012 acting weird
2012 acting weird
Having a weird issue with my JKU the last 2 days. Get in vehicle, fasten seat belt, crank it, engine fires up, runs for about 5 sec then dies. Crank it up again and motor cranks and cranks but no fired. Turn it off, pump pedal, crank, engine fires up runs for 10 seconds and dies. Crank it again, crank and crank but no fire. Pump pedal 3 or 4 times crank and engine fires up no issues.
Tonite same issue but takes about 10 min to fire up and wouldn't fire until I turned off traction control, and what is it ESB?
Anyone have the same issue or have a clue on what might be causing it?
Turn your Ignition to the on but not start position wait till all the lights go out the cycle the key off to on 3 times stopping in the on position and it should show a code where your km are if it isn't throwing any codes you'll just see dashes then the word done. Once you have the code if any, search this forum for codes and there is a list of what each one means. This will give you an idea. Maybe it's a clogged fuel filter, bad fuel pump or maybe it's something in the computer. Regardless I would take it to the dealer.
Sorry RedRock. I feel like I've read more than my share of posts on '12 issues, but I haven't heard anything close to what is happening to your JK.
Hope it's something minor. Keep us posted.
I've had a similar problem the last two weeks (5,500 miles), except mine would die when coming to a stop or after stopped. Dealer had it all weekend, and it cut off on them several times while idling. No codes and no check engine light. They finally traced the problem to a loose connector # C105 under the battery tray. I believe they had to remove the right side inner splash guard in the wheel well to access it, judging from the finger mark smudges everywhere. Hope this helps!
Mark
Mark
Well just to update you on the problem...It hasn't happened again, and I did nothing. The assumption is that perhaps bad gas or dirty injectors. Seems a litttle early for that problem but ran some injector cleaner in there anyways. So far no more issues, and fingers are crossed
My actual guess would have been bad gas...If there were no cdes...Did you go to a
different place for gas...Once a month i run a tank of super unleaded to clean injectors
and lines...Glad yours is all fixed up...
Kind of guesswork on my part but maybe it's the security system or the key. You could try a different key. The red light on the dash might be doing something if this is it but I'm not sure.
