2012 Infinity Subwoofer
Old Feb 3, 2012 | 11:57 AM
FlMtnClimber's Avatar
Default 2012 Infinity Subwoofer
Does any one know if the stock infinity subwoofer on the 2012 is temporarily removable ? I would just want to remove it to make room for hauling large items . Is it just a plug in jack or is it hard wired ?
Old Feb 3, 2012 | 07:29 PM
brad2012's Avatar
it is easily removable. 2 bolts hold the panel to the floor. there is a plug in the upper right corner.
Old Feb 4, 2012 | 03:07 AM
Thanks for the help
Old Feb 4, 2012 | 06:14 AM
crankinaway's Avatar
I wouldn't call it easy. Yes there are two bolts in the bottom, but there is also a small tab right around the seatbelt mechanism with a nut and stud. You have to look hard but its there. The other part of it is you have to slide the seat belt trim ring up the rool bar and un-snap the two upper plastic panels above the sub box.
Old Feb 4, 2012 | 08:31 AM
azyjjk's Avatar
What about the brace that holds the tailgate open?
Old Feb 4, 2012 | 09:52 AM
The tailgate brace is attached to the body and remains when you remove the enclosure.
