2012 jk 2.8crd p0706 fault code
Old May 9, 2024 | 12:55 AM
Penny67's Avatar
Default 2012 jk 2.8crd p0706 fault code
Hi guys,
​​​​​​Newbie jeep owner and looking for some help.
It's a 2012 jk 2.8crd diesel with a 6 speed manual transmission.
Car runs and drives fine, no check engine light, took her for the annual test and they check the ECU codes, it came up with a p0706 error, so failed.
Doing some research and this seems to relate to transmission range sensor on an auto, but my car is a manual, and I can't find any info relating to this code on manual cars.
​​​​​​Garage reset the code, drive around the block, check again and it's back.
Just checked now with the key on/off test and no codes showing, just dashes and then done.
​Can anybody offer any advice please?
Many thanks
Old May 12, 2024 | 03:19 PM
RLT's Avatar
RLT
That's crazy.
Yearly MOT test in UK just tests the exhaust smoke on the Diesel. ( mines a 6 speed manual 2007)
This must be one of those EU directives to make it more difficult to own a private vehicle.
I would check to see what wiring / connectors there may be linked to the manual box that may be an issue
Would changing the gear box oil make a difference I wonder ?
Could it be the ECU is programmed to look for the sensor, ( as most Wranglers are auto's) with it not being there registers the code in the memory anyway and is irrelevant to the running of the engine ?
I've never used a code reader on mine so wouldn't know if such a code would appear.
Have you checked it out with an official JEEP dealership ?
