2013 JKUR burnt oil smell
I have 2013 unlimited rubicon and have noticed that when I get on it, I get a burnt oil smell coming through the ventilation. I changed my oil at 500 and just recently at 3000. No spills no visible leaks. Anyone else seen this? It's an auto with 3.73 gears. My 07 rubicon and 2010 unlimited have never done this. I realize its the new motor but this is bizarre. I used Mobil 1 5w20 for the first oil change and went to 5w30 since I live in SW Florida and it rarely gets below 40 deg here. Is this just the new motor getting broken in?
I changed mine at about the same intervals as you and now have 5000 miles and never have had any unusual smells. Seems like any oil/lube/grease should have long been burned off.
Check the filter under the cover. Mine was leaking after the 3rd oil change (7xxx) and I noticed it running down the side of my motor. I didn't smell anything but I could easily see a burning oil smell if it somehow you touched a manifold or something
