265/70/17 on stock jeep?
Old Aug 5, 2012 | 05:29 AM
webejeepin's Avatar
Good info thanks to all that posted.
Running 265/70/17 did any of you need to 're-program' for this size, or no need to worry as most of you noted only a bit wider.
By my homework I have the following:
OEM
255/75/17
Tread width = 7.5"
Over all diaamter = 32.1'
Aftermarket
265/70/17
Treae width = 8.4"
Overall diameter = 31.7
FYI I'm doing my comparrison to the stock tires on my Sahara Bridgestones vs the Mickey T ATZ Radials
Old Nov 26, 2012 | 02:45 AM
doc5339's Avatar
Veteran: Navy
OEM
255/75/17
Tread width = 7.5"
Aftermarket
265/70/17
Treae width = 8.4"
on my 2013 JKUR, I will do this size (265 70 17) if I end-up installing:
-BF Goodrich Rugged Terrain T/A
-BF Goodrich All-Terrain T/A KO
-Michelin LTX A/T2
I will stay stock (255 75 17) if I do:
-Goodyear Wrangler SilentArmor
-Cooper Discoverer A/T3
It does not seem like you should have to recalibrate your Speed due to such a small difference in overall diameter, but maybe one must?
Old Nov 26, 2012 | 11:44 AM
R.C's Avatar
R.C
Originally Posted by SarJ
I'm running 285/70/17 on a stock, trail rated JK 2 Door with minor rubbing when turning on uneven ground. Other than that, no issues.Attachment 294858
Do you have wheel spacers? I'm looking to get the same size tires for my 2012 4door unlimited sport. I have a 2.5' TF suspension lift w/ 5100 series Bilstein shocks. If so,would u know the correct back spacing i woud need w/ after market rims,where i dont have to use spacers?
Old Mar 6, 2020 | 07:32 PM
Rollie Flores's Avatar
265/70r17 from the back-right side.
From the left side.
From the front.
Old Mar 7, 2020 | 06:59 AM
AJMBLAZER's Avatar
Wow. Dug this one up from the dead huh?
Nearly 8 years.
Old Mar 8, 2020 | 06:41 PM
Bob Roach's Avatar
I just replaced my Goodyear Silent Armor 255/75R-17's with Cooper Discoverer 265/70R-17 S/T MAXX tires.
I have a 2 Door 2013 MOAB with the stock Rubicon/MOAB "BLACK" wheels. No problems at all, and no reprogramming required.
My research indicated that a 265/70R-17 was about as wide as I could run with no issues what so ever with stock wheels, and No Spacers.
This is an E rated tire running at 35 psi. I do not notice the ride being much rougher than my Silent Armor tires.
My research indicated that this was a very good all round Jeep Tire giving good traction in most conditions while also delivering good tire mileage. I suspect that this is about as aggressive a tread pattern that I can run and still get good tire mileage.
I am expecting at least 45K on this set of tires doing a 5 tire rotation every 5K.
Another good selling point for me, they say Made In The USA on the sidewalls. Something you will not find on many A/T or M/T tires today.
Bob R
