2WD Question
Old Dec 17, 2011 | 06:00 AM
EClass's Avatar
Default 2WD Question
My neighbor bought a 2007 4dr for his son a few months ago as a College graduation present. It is only a 2WD. He wants to add 33"-35" tires mainly for looks. What gears are in the Unlimited X 2WD? Can they handle 35" tires? Are they the same in the rear as the 4WD? I couldn't find the answer but knew one of you guys would know!! Thanks.
--E
Old Dec 17, 2011 | 06:09 AM
EClass's Avatar
Originally Posted by Soul Rebel
what color is this jeep..
Black. Didn't know the color mattered!?!
Old Dec 17, 2011 | 06:13 AM
jaker t5's Avatar
2wd can handle any tire a 4wd can and that means you will have to beef up the front axle the same to if you go bigger and bigger , as far as gears there are a couple of ways to find out but the easiest is to get a build sheet , but everthing is the same in the rear
Old Dec 17, 2011 | 06:17 AM
EClass's Avatar
I will let him know. Thanks.
Old Dec 17, 2011 | 07:34 AM
EClass's Avatar
..I sold my 2wd black unlimited and i think this is it. I would like a picture of it whenever you can take it. I would GREATLY appricitate it i miss it
10-4. I will see what I can do. It had around 70K on it when he bought it I believe. If that helps narrow down your curiosity.
Old Dec 17, 2011 | 07:40 AM
EClass's Avatar
... thats how much mine had, is it a sahara?
Unlimited X. EDIT: It has the 16" steelies on it right now.
Old Dec 17, 2011 | 09:16 AM
duneslider's Avatar
I think all the 2wd had a d35 in back and I can't remember the gear, might have been 3.73.
I would stick with 33, but that's just me.
Old Dec 17, 2011 | 10:03 AM
EClass's Avatar
I just saw a post about build sheets on jeep.com and told my neighbor.
He signed up and just called me. Come to find out he has Dana 44 with a 4.10 ratio. Is higher or lower better? I am not familiar on how the gearing works.
Old Dec 17, 2011 | 11:54 AM
jaker t5's Avatar
2wd have and all wrangler execpt rubi's ( different spline count but still a 44)have a Dana 44 in the rear , 4.10 gears are fine for the most part but he needs to figure out what size tires he wants before he thanks about regearing first and he can run what ever tire size he wants as long as he wants to beef up the axle
Old Dec 17, 2011 | 12:43 PM
IndyChavez's Avatar
I got a 2wd. :sad: but almost have all the parts to do the conversion. . Back to the op. I have a d30 in the front and a d44 in the back with 4.10's. It's lifted and has 33's. It drives pretty good.
