3.8 engine
I'm not sure exactly what design Chrysler used on the 3.8L V6, but this was a popular mod on Fords here where I am the back in the mid-90's.
In '94 Ford added a variable intake manifold with dual-length intake runners to the EFI system on their 4.0L I6 to greatly improve high-end performance without compromising low-end grunt, and it was a popular mod back then for the young Fast 'n Furious types to add this setup (usually sourced cheaply second-hand from a wrecked newer car) to pre-'94 motors to get some extra grunt (I believe the difference was about 30-40HP, so similar to the gains on the Chrysler V6 motor). On those motors it was a simple plug & play swap-out of the intake manifold and accompanying throttle body, intake runners & airbox though I'm pretty certain the PCM then had to be flashed to accomodate this.
Depending on how the Chrysler system is set-up is it could either be doable, or way too tricky to attempt; you'd need to get hold of a minivan with that motor and compare the intake set-up with the one on the Wrangler motor. I suspect that the valves that operate the system are deep in the lower intake manifold as is the case with some other V6s using the system which would mean a complete swap out of the entire manifold system, which is far more complex than the simpler one-piece I6 manifold; there's other simpler and more proven ways to get an extra 20-odd HP on a Wrangler motor than this (chipping, long-tube headers, free-flowing exhausts, etc).
Funny, but in reality, this mod makes since. Anyone do this?
i love my V6...it's better than the 2.5 turbo diesels i've had in the past...
it propells my 'brick' quick enough for me thank you very much...
Up against the old 4.0...
