33 inch tires with no lift
Old 01-07-2012, 05:22 PM
nygiamtz12's Avatar
Default 33 inch tires with no lift
Does anyone know if I can run 33 inch Goodyear wrangler SilentArmor's on my 2012 sport with no lift, will their be any fender rubbing while turning or going over bumps?
Old 01-07-2012, 05:24 PM
CanadianRubi's Avatar
Considering factory tires equate to 32" you'll have no problem at all.
Old 01-07-2012, 05:26 PM
flatattack's Avatar
I'm running a 2012 Sport with MT Baja TTC 33"s on stock suspension with no rubbing. However I have only been in some mild offroading situations.
Old 01-07-2012, 05:28 PM
Battlefrog's Avatar
Not always true... If your running a 33x12.50 on stock rims, it might rub at full turn.. It's not so much the height being the issue, it's the width..
Old 01-07-2012, 05:32 PM
flatattack's Avatar
Probably true, I'm running 33X10.50's on a 17X9in wheel.
Old 01-07-2012, 05:41 PM
Battlefrog's Avatar
Your BS is most likely 4.5-5" and the stocks are 6.5" I believe and rims are 17x7.5 (on phone and can't scroll to see if he is running 17 or 18)...
Old 01-07-2012, 05:42 PM
flatattack's Avatar
Correct, My backspacing is 4.5in.
Old 01-07-2012, 05:46 PM
nygiamtz12's Avatar
This is what i want to run 275/70R18 and 18x9 KMC XD's
Old 01-07-2012, 05:59 PM
Battlefrog's Avatar
Then yes, you will be fine... Flat, you are correct! Haha
Old 01-07-2012, 06:00 PM
flatattack's Avatar
A quick calculation puts that at a 33X10.5.
Shouldn't have a problem.
Quick Reply: 33 inch tires with no lift
