4.10's
I live in TX and have 4.10's with 33 inch tires. I don't think the Jeep is a speed demon but don't think it is horrible right now. Question I have is if I add a superchip programmer with 35's would I still be happy. I plan on adding km2 which are about 34 inch and right now my tires measure 32. Will I notice much of a difference in power just going up 2 in and adding a programmer. Thoughts
P,S i have the superchip prodrammer but have it set on stock, once i put my bumpers on , i will prob change the stock setting then determine if i need to regear... hope thie helps
Just depends on the weight of the tire, as I would imagine some 33s may even weigh more than some 35s. Can you look up the weight of the KM2s and compare? If it's only a slight difference then you may not notice much. But if it's a lot..........well....
All I know is that when I installed the Flashpaq in mine, it gave me more power with my 33s and new wheels, than I had with the dinky stock tires and wheels. I don't know what the weight difference is tho.........I should check that someday.
Oh and btw........I do also have an Airaid CAI and that helps a little too.
