Sponsored by:
Sponsored by: DashLynx
5w-40 oil analysis results
Old 04-06-2017, 10:55 PM
  #141
Mr.T's Avatar
Originally Posted by zstairlessone
But normally a 40W at 100° C is on the 13.7 to 15.3 cS range. If I was looking at a 12.1 with a 40W I would be checking for fuel dilution (diesel) or someone putting the wrong oil in it. But that's just me
I just read the data sheets, there are too many oils that don't hit the center of the range for a given grade with your rule-of-thumb.
Another example of an oil close to the dividing line between grade 30 and 40 is Amsoil EFO 0w-40 [European classic], it is 13.3 cst out of the bottle.
Recall that M1 5w-30 HM was 12.1 cst, and 12.5 cst is the grade 30-40 dividing line. The difference between 12.4 and 13.3 cst is nada, yet one is grade 40 and the other is grade 30. Without reading the data sheet you might start looking for an imaginary problem!
Old 07-26-2017, 11:38 AM
  #142
Mr.T's Avatar
Default Oil consumption @ 4200 miles with 0w-40
Name:	20170726 oil level 85200M.jpg
Cold oil level after 4200 miles, 85200 miles total. About half way into this oil change interval, no oil added. If anything, oil consumption looks slightly less with 0w-40 -- Maybe a couple ounces in 4200 miles and the color looks normal.
Originally Posted by Mr.T
Changed oil yesterday, went with 0w-40 this time + the NAPA oversize filter (41516).
Eventually I'll post a used oil analyses, curious if there will be any noticeable difference compared with 5w-40 UOA's previously posted. Like most diesel rated oils, DZF 0w-40 has both gasoline (SN) and diesel (CK-4) engine ratings.
Next on my to-do list: The diffs, tranny, and xfer-case are all getting fresh oil!
Old 11-13-2017, 06:27 PM
  #143
Mr.T's Avatar
Default 0w-40 UOA 8600 mile OCI
Oil: Amsoil DZF 0w-40 (diesel/gasoline rated)
Filter: NAPA PFL 41516 (oversize, same as Jeep Liberty 3.7L)
OCI: 8600 miles
Oil added during OCI: NONE (1/2 qt low on stick)
Total miles: 89700
Aluminum (AL) 2 ppm
Iron (FE) 13 ppm
Copper (CU) 14 ppm
Lead (PB) 0 ppm
Tin (SN) 0 ppm
Chromium (CR) 0 ppm
Nickel 0 ppm
Cadmium 0 ppm
Silver 0 ppm
Vanadium 0 ppm
Silicon 16 ppm
Sodium 9 ppm
TBN 3.5
Wear metals are all low, especially for an 8600 mile OCI, and it's running great. Amsoil AZF 0w-40 was installed at this OCI, which is rated for gasoline only (DZF 0w-40 is rated for both diesel & gasoline). For reference, PDF data sheets are below.
Amsoil AZF 0w-40.pdf
Amsoil DZF_5w-40_2017.pdf
Old 11-13-2017, 09:08 PM
  #144
jtphoto JK's Avatar
Thank you for the update. I found no difference in oil consumption ( approximately 1/2 quart every 10,000klm ) between Amsoil 5W30XL and Amsoil Euro 5W40. The next oil change I am going to change to traditional weight Amsoil 10W30XL which is the weight the 3.8 was originally designed to run on.
My engine has just turned 290,000klm.
Old 11-13-2017, 09:35 PM
  #145
Mr.T's Avatar
You're very welcome, good to hear from you. What's your typical oil change interval?
[Edit] Just noticed you implied a 10,000 km OCI. That's what happens with late night speed reading...
Last edited by Mr.T; 11-14-2017 at 09:00 AM. Reason: [edit] regarding late night speed reading!
Old 11-14-2017, 06:00 PM
  #146
jtphoto JK's Avatar
That is correct. In 2008 the factory warranty manual specified 10,000klm OCI.
Old 05-24-2018, 11:57 AM
  #147
Mr.T's Avatar
Post 6800 mile OCI -- Wear Metals Triple...
The engine is running better than ever, but iron, aluminum, chrome and silicon are up in this sample. However, it's not abnormal for an engine to occasionally have some moderately higher values and I had a feeling the numbers would increase this time. Looking back at this OCI (oil change interval) here's what I suspect:
  • Previous wear metal readings were low, so increases to even moderate levels are magnified by comparison. Chrome (3 ppm) was actually the only wear metal flagged "abnormal". 2 ppm is probably their abnormal limit.
  • Higher silicon could mean more dirty air, which is abrasive and causes higher metal wear. This OCI had more following other Jeeps on dusty roads. Also wondering about changes to air filter efficiency as it relates to periodic cleaning of the AEM filter. Considering going back to the OEM style replaceable filter.
  • There was a bad O2 sensor during this OCI and fuel trim on one bank went high for a short while. It ran rough until it failed hard, so it was likely washing the cylinder walls of oil. At 10 years and nearing 100K miles, it was a good time to replace all four O2 sensors.
  • This OCI had a lot of wide open throttle runs during tuning with VCM Suite (HPTuners).
Oil: Amsoil AZF 0w-40
OCI: 6800 miles
Oil added during OCI: NONE (almost 1 qt low on stick)
Total miles: 96500
Aluminum (AL) 11 ppm
Iron (FE) 45 ppm
Copper (CU) 14 ppm
Lead (PB) 0 ppm
Tin (SN) 0 ppm
Chromium (CR) 3 ppm
Nickel 1 ppm
Cadmium 0 ppm
Silver 0 ppm
Vanadium 0 ppm
Silicon 33 ppm
Sodium 11 ppm
TBN 3.6
Old 05-24-2018, 07:53 PM
  #148
jedg's Avatar
I have to admit, it's pretty interesting to keep up with this on your jeep. hahaha
Old 05-24-2018, 08:17 PM
  #149
Mr.T's Avatar
Default Air Filter Swap
Hell, I wouldn't be able to resist reading this either. Can't be too many long term oil analyses in real time over the years, at least I haven't seen any.
As a side note, I just changed out the AEM washable filter for a OEM style NAPA Gold air filter. That silicon reading jumped too much, and there was some light dust in the intake. I have a differential pressure monitor on the filter housing -- Did a quick run to 5K RPM at full throttle to see if there's any difference between the AEM and NAPA. Both were ~10" water differential, so as far as filter restriction they're fairly equal.
Old 05-25-2018, 01:04 PM
  #150
Rednroll's Avatar
Yes, this is incredible data. Unfortunately, for myself it's the 1st time I've read "parts" of it. Full Disclosure: I read your 1st post, scanned down some and then jumped to the end.
What I was curious about is if you ever ran an analysis on your oil prior to use? Or is it a known assumption that prior to use things like 3PPM AL, 12PPM CU, 18PPM Si, etc would all be 0PPM prior to use? I guess what I'm trying to determine is what parts did the oil pick up from use, and which parts may have already been present as part of the new oil mixture?
Quick Reply: 5w-40 oil analysis results
