6-Speed 3.6L Starting Off From 2nd Gear
Old Dec 21, 2013 | 04:35 PM
  #31
Bonedoc's Avatar
Originally Posted by bfschor
I'm not into the clutch much longer than when I start off in 1st, so I'm not worried about that. What I'm trying to do is find more low-end power. It's the same as if I'm rolling, in 2nd gear, at low RPM's, and mash the go-pedal and there's not a lot of pep until I hit that 1800 RPM mark. Doing the same in 1st gear.....let out the clutch, let the engine idle it down the road, but when I mash the pedal, there's good power all through the low (below 1800) RPM's. I understand about it being a factor of 1st gear vs 2nd and lower gears having more low-end power and all.......I guess I'm confused at why don't I get any pep in 2nd gear until I break that 1800 RPM? And it's instant...not like it builds up to it.
I think I follow you better now. The programmer may be your best bet then. The reason it lags may be something built into the engine's program. I know that mine has a flat spot in the power band between 1500 and 2000 rpms. I figured it was just because it was the 3.8L. I thought it was something that they improved or remedied with the 3.6L. I did a superchips flash paq on mine, it eliminated pedal lag and was useful to adjust my speedometer for my gears and tires, and shut off my tpms. Other than that it did nothing for that flat spot. For mine if I lug it in a higher gear it will be flat till it hits about 2k then it takes off. If I drop a gear it will take off right away as well.
As mentioned by another poster they did the flash paq and it worked. May be it is something that got remedied for the 3.6L. Keep us posted.
Old Dec 22, 2013 | 10:26 AM
  #32
FDHog's Avatar
Originally Posted by Bonedoc
The question is how long do you want your clutch to last? To me, if you drive a clutch properly it can easily last the life of a vehicle. I read posts of people having to replace their clutches with under 100K on their vehicles and I cringe. Yes it is a wear item but all you have to do is remember a few easy things and it can last a very long time.
I want to see you get a clutch to last 100K living in the NYC area. I probably shift more times in a day than you do in a month. I've been driving a stick for 42 yrs and have yet to have one last 100K.
