About grease
Old Mar 29, 2009 | 07:47 AM
Yoda's Avatar
Default About grease
Do you know a write-up or a link where I can find a list of all the parts who have to be greased ?
Old Mar 29, 2009 | 07:54 AM
ronjenx's Avatar
If you are talking about grease fittings, here is a complete list:
-----0-----
This is from the Owner's Manual:
Driveline And Steering Component Lubrication
All driveline and steering components are sealed and do
not require lubrication. Driveshafts are not serviceable.
Body Lubrication
Locks and all body pivot points, including such items as
seat tracks, doors, tailgate and hood hinges, should be
lubricated periodically to assure quiet, easy operation
and to protect against rust and wear. Prior to the application
of any lubricant, the parts concerned should be
wiped clean to remove dust and grit; after lubricating
excess oil and grease should be removed. Particular
attention should also be given to hood latching components
to insure proper function. When performing other
underhood services, the hood latch, release mechanism
and safety catch should be cleaned and lubricated.
Old Mar 29, 2009 | 10:51 AM
Yoda's Avatar
-----0-----
I don't know if I should laugh or cry
Anyway thanks for the info.
My adj control arms will be the only parts to grease...
Old Mar 29, 2009 | 01:25 PM
Hellbound13's Avatar
You can use a grease needle on the tie rod and drag link ends.
