ABS wiring harness repair.
Last week we ran the Mojave Road. On day one, while taking advantage of a few opportunities to flex I got a hand full of lights on the warning panel. A quick inspection revealed no leaking fluids, the brakes worked, so we soldiered on. Today I took the opportunity to do a little investigation and found the culprit, during some body roll the right rear abs speed sensor harness was crushed between the two mounts. I went to a couple of parts places and found the harnesses out of stock so I spliced in a couple of short lengths of 18GA wire and now all is good to go. This is an easy repair, that anyone with even the most minimal mechanical ability can knock out.
