Accessing the void behind the glove compartment
My glasses that were in the glove compartment seem to have fallen back and inside the area of the glove (when you open up the glove you can see a void back there), is there any easy way to get at it? Thanks!
push the two sides of the glove box towards the center and remove it. Takes less time than writing your post. You can also then pry the panel under it off. It's just plastic snaps. I doubt you will need to do this though.
Another access point is the panels on the side of the dash. You can put your fingers in the vent and turn it and it will pop out. Then you can stick your hand in and pop out the side panel of the dash (the part against the door). You will have to have the glove box out probably to have room to push the side panel.
