Adding DRL to LED headlights?
Rookie here and I have installed my Seward, Nightvision, URB, LED headlights and no issue with the plug and play. I do have a pigtail that could be connected for DRLS to illuminate the top and bottom "ribbon" of the headlight on my 2014 JKU. I bought a Add a Fuse and some 18 gauge wire to complete the project and have some questions:
What spot do I use the Add A Fuse so that the DRLS are operational with the ignition?
How did you create the hole in the TIPM box, burning nail or drill? Then what was used to seal the hole once the wire is through the hole in the TIPM box?
Wiring I use the 18 gauge wire or do I need something thicker? I figure run the wire from drivers side light pigtail with the 18 gauge wire, connect with the passenger side pigtail, then connect to the Add a Fuse wire coming out of the TIPM, sound right? TIA much appreciated!
https://www.jk-forum.com/forums/jk-e...source-191552/
As far as what gauge wire, that is a factor of both draw and length. Without knowing those, I can't recommend anything beyond my standard practices. I use a relay on anything drawing 5 amps or more. I don't on less than 5 amps. If you run the wire as described, the first leg will have the draw of both lights combined so make sure you consider that. Also, if you only know the wattage of the DRLs you can calculate the amps using watts/voltage=amps. Once you know the draw and an estimate of wire length you can use an online calculator for wire gauge. I use this one...
http://www.wirebarn.com/Wire-Calculator-_ep_41.html
LED lights do not like the DRL function. they flicker etc. I turned mine off. I now have my front markers as my DRL on bright. Much better. It was just annoying seeing the headlights flicker, and spazz out all the time on DRL.
Agreed they will flicker and witch can be fix with a relay kit .the reason they flicker is because there are running off the high beam circuit at a lower voltage and use pulse signal. best to use relay kit so power is taken from battery and trigard or use as stated aev procal to switch to markers and tie into that or fogs
You should be using an anti-flicker harness with LED headlights. ( One for each headlight ) If yours did not come with one you could buy them separately. Truck-Lite - Catalog Product : Anti-Flicker (PWM) Adaptor For 2007-2013 Jeep® JK I used the M7 fuse slot which I believe is for a rear power outlet ( which I don't have ) for my DRL. This fuse slot has 2 positions, 1 for ignition switched and 1 for constant on. I drilled a small hole in the plastic fuse box for the #18 wire and sealed it up with silicone.
